Pretty sure me and my brother can muscle the 2-stroke off. Or get my nephew who is like a linebacker.
Then going to replace the transom (was going to have to do this anyways)
4-stroke is brand new, in box, never seen water. Dealer said it would be fine to just leave it crated for the winter (in my garage) and install it in the spring.
I've seen several guys on here that have done motor swaps. What would you say is the safest way to lift the 40 onto the boat? I believe it comes with the lifting eye. It will be laying flat on its side as that's how it is in the crate. I am guessing I have to somehow peel off enough packing to get the cowl off and attach the lifting eye (...pretty sure it's the kind that screws into the flywheel... not a permanent one , but I could be wrong about that).... so #1 I have to get it upright. Then actually lift it and get it to the boat.
I turn 65 on Wednesday. So not exactly a spring chicken, but still not afraid of some grunt work. I'd mainly like to see if I can make this easier and be sure nobody gets hurt in the process. I weight 208 pounds. If I fell on someone it'd hurt. And I don't have sharp edges. And... I know I can lift my brother off his feet (he weighs about the same as me) in a bear hug type lift, but not for long
So.... 2-stroke comes off, I inspect the transom pod just to make sure all the mountings are in good shape, no cracks, etc.... replace transom wood.... then hang this 200 pound motor on it.
Ding! A little light goes on in my head..... "you just DOUBLED the weight of that hunk of meat hanging at the very farthest back of your boat. You might want to check your trailer's tongue weight!"
I was thinking of making a stand for the 4-stroke, unboxing it, and getting it standing upright for the winter. Believe it or not I think that'd take up less room than the crate it's in. The crate is 69 inches x 49 inches x 24 inches. If I build the stand, I would put really decent casters on it.
So my next question would be.... do any of you in cold climates, remove the motor from the boat for the winter? My boat will not be in a garage, but it WILL be covered. I think most people around here leave motors on and just make sure they're covered well. Because if that's the case, then I'm kinda stuck with an engine stand to store and never use.... until the next time I have to replace the transom....
I'd be interested in hearing your thoughts on all this.
