Table Mounts - Thread Lock vs. Sequoia mounting systems
steve1313
#1 Post by steve1313 » Tue Oct 03, 2017 4:19 am
I want to add a table but I don't want to drill a hole for the post in my floor. I've found two different flush mounting systems (Thread-Lock and Sequoia) and was wondering if anybody had any experience, pros/cons of either system. Thanks!
teecro
Re: Table Mounts - Thread Lock vs. Sequoia mounting systems
#2 Post by teecro » Tue Oct 03, 2017 6:26 am
I have used both the Sequoia and Redwood by ITC they are both no hold drill to mount. The Sequoia has a smaller flatter base and seems stronger in my opinion as it uses a 3 winged flange to wedge up whereas the Redwood uses a small bi-winged bolt. Since I'm using my table to support an umbrella for extra shade I wish that I actually had the mount that uses a large hole with a support cup in place of the Redwood as the bot came with.
smltooner
#3 Post by smltooner » Tue Oct 03, 2017 6:16 pm
My Sun Tracker Party Barge came w/ a Sequoia system at the bow and I added a second one at the rear L-shaped seats. We have been very happy with them. They are very sturdy.
SMLTOONER
Ted & Emily
2019 Bennington 21SL Tri-toon
2019 Yamaha 150 HP
Smith Mtn. Lake, Virginia
Opie
#4 Post by Opie » Wed Oct 04, 2017 4:11 pm
Do you have a picture of the two different types? I have ordered a Harris, and it looks like a flat flange (no hole in the deck) with cam clamps on the table base attached to the table pole.
2018 Harris Sunliner 200/Merc 115 Pro XS
smltooner
#5 Post by smltooner » Wed Oct 04, 2017 5:58 pm
This link shows the Sequoia mount that I have.
http://www.overtons.com/modperl/product ... em&i=79554
SMLTOONER
Ted & Emily
2019 Yamaha 150 HP
teecro
#6 Post by teecro » Wed Oct 04, 2017 6:45 pm
[quote="Opie"]Do you have a picture of the two different types? I have ordered a Harris, and it looks like a flat flange (no hole in the deck) with cam clamps on the table base attached to the table pole.[/quote]
I think Harris uses their own...
http://www.itc-marine.com/product-categ ... g-systems/
steve1313
#7 Post by steve1313 » Thu Oct 05, 2017 3:17 am
[quote="teecro"][quote="Opie"]Do you have a picture of the two different types? I have ordered a Harris, and it looks like a flat flange (no hole in the deck) with cam clamps on the table base attached to the table pole.[/quote]
http://www.itc-marine.com/product-categ ... g-systems/[/quote]
Here's the thread lock one that I bought. I ended up buying two tables with both systems and figured I'd return the one I didn't like. I installed the Sequoia yesterday and it's plenty strong enough at the base. The only thing I didn't like was the table top spins freely when installed. I'll fix that with a cotter pin, so I think I'm all set.
https://www.amazon.com/gp/product/B002I ... UTF8&psc=1
Opie - It's a little hard to tell from your picture, but it looks like if you remove your table the base could be a real toe stubber! It also looks like the seat mounts are the thread-lock system.
tkrein
#8 Post by tkrein » Thu Oct 05, 2017 5:05 pm
I f I wanted to add another table I would add the same mount that is already on the boat that way I could move the tables around, and then it looks uniformed. But If I had an older boat I would just do the cheapest and safest way.
2017 Bennington 22ssrx
115 Yamaha
karavan Trailer
2014 Chev tahoe
_________________________
Port Of Bismarck ND
teecro
#9 Post by teecro » Thu Oct 05, 2017 6:11 pm
[quote="tkrein"]I f I wanted to add another table I would add the same mount that is already on the boat that way I could move the tables around, and then it looks uniformed. But If I had an older boat I would just do the cheapest and safest way.[/quote]
This is what I did in both cases. The Sun Tracker used the Sequoia mount and it worked great being able to move the table around and the base is very unobtrusive and flat. The Berkshire used the Redwood and while it is a little larger least it is not a toe stubber; but I just don't think it is as strong at the Sequoia.
Tooner606
#10 Post by Tooner606 » Fri Oct 06, 2017 4:05 am
"Do you have a picture of the two different types?"
table bases.jpg (117.88 KiB) Viewed 6878 times
Opie
#11 Post by Opie » Fri Oct 06, 2017 7:20 am
This is the one Harris uses, not really a toe stubber, they also give a cover to use when the table is out.
Table base.JPG (18.6 KiB) Viewed 6854 times
