Need help identifying part.
mmuscaro
#1 Post by mmuscaro » Fri Jun 15, 2018 10:53 am
This is on the right side of transom. You can see where that piece is cracked. Left one is already gone and this one went this weekend. I assume it has something to do with directing water flow?
Thanks in advance.
mmuscaro
Re: Need help identifying part.
#2 Post by mmuscaro » Thu Jun 28, 2018 9:07 am
Any thoughts?
FLOUNDERPOUNDER225
#3 Post by FLOUNDERPOUNDER225 » Thu Jun 28, 2018 9:24 am
The pic is way too large, you can't get any perspective of the area in relation to the rest of the stern area. Take one not so close and I think it will be easier to identify by comparing the 2 pics.
Pensacola FL
2015 Berkshire 231 RFC
Yamaha F-150
#4 Post by bansil » Thu Jun 28, 2018 1:26 pm
Agree back camera off, since it has adjustability I will guess....
A splash shield :mrgreen:
what is interesting? the cut/grinded section that the splash shield is covering (notice "lip" left from cut off wheel?)
Need another picture
mmuscaro
#5 Post by mmuscaro » Fri Jul 06, 2018 4:31 am
Thank you. I will post new pictures tonight.
zoom650
#6 Post by zoom650 » Fri Jul 06, 2018 11:43 am
Might help to know what make and model you're floating there.
I broke a cross member under the plywood deck. Took it to a metal fab shop and they couldn't weld it, the tear was so close to the deck. Instead, they bolted a brace in place and splinted/sistered it back together. If that's on your transom, maybe it needs some beefing up.
BobG
#7 Post by BobG » Wed Jul 18, 2018 12:23 pm
There is no "right side of the transom", but there might be a "wrong side".
Is that the starboard side?
Probably the starboard rectilinear modulator excursion bracket.
