How fast do you drive with your Bimini top
My manual says not to exceed 15 mph with the Bimini top open. That seems a little overly cautious. How fast are you comfortable going with your top open?
Re: How fast do you drive with your Bimini top
Mine only goes 18 mph at WOT, so I always leave mine up.
However, I have had a front clip, that connects the bimini frame to the rail, snap while riding in high wind.
This has happened twice. It did not hurt the cover, but the bimini frame is 2-3" out of square now.
SMLTOONER
Ted & Emily
2019 Bennington 21SL Tri-toon
2019 Yamaha 150 HP
Smith Mtn. Lake, Virginia
Ted & Emily
2019 Yamaha 150 HP
I would fun my Manitou's and Premier WOT with them up. No harm. Just remember to pull them down before you pull into your slip. That's the killer! Don't ask....
Run my Crest WOT as well. My front support is frame If you have a strap and clip you may need to go slower.
I only deploy my bimini once or twice a year (we love the sun!), but when I do I don't hesitate to run at WOT (~40mph). No straps on my Sweetwater, just full metal frame with front supports, too.
FYI, I wanted to buy a Power-Arm motorized top, but the max speed limit is something like 20mph, so that was a deal killer for me.
- FLOUNDERPOUNDER225
WOT 38-40 MPH, full aluminum frame, no straps
Pensacola FL
2015 Berkshire 231 RFC
Yamaha F-150
Yamaha F-150
- rancherlee
37-38mph into a strong headwind, no issues and I have the straps up front, 12' 4 bow top. A lot has to do with the way its mounted, the front on mine is slightly lower than the rear so it doesn't act like a parachute.
I've run mine at a whopping 24 mph ( wot ) with the top up.. no problems here.
Thanks. Mine is full aluminum frame with no straps. My boat will do 31 so guess I’m okay
WOT over 40 numerous times for a few mins or more. My G2 motor gets the same MPG"S at WOT as it does at 4000 rpms. The faster I go the MPG"s stay the same its crazy.
Last time out, I got 38 mph with only the 12ft rear bimini open. When I bought, the dealer towed her to the lake for a test run. Both biminis up, he drove 40 to the lake.
W>A>O>
Broken Arrow Ok
2014 G3 Suncatcher
115 Yamaha 4 stroke
2014 G3 Suncatcher
115 Yamaha 4 stroke
^^This^^
I've never seen it flap/move enough to make me want to slow down, or take it down.
2019 Veranda 22 RFL 250SHO
I will run it up to 35 mph with no issues in our Premier. I do watch if I am running with the wind or into it. This is only for the rear Bimini. I never run with the front Bimini deployed.
Jeff
Peggy Sue
25 x 10' 2009 Premier Escapade
225 Mercury Verado
Peggy Sue
225 Mercury Verado
Mach 3.2
