Maybe they will provide "pin striping" to hide the difference.Rick McC. wrote: ↑Wed Oct 03, 2018 7:57 pmOur Bentley sits deeper on the port side, as the fuel tank is located at that rear corner of the boat.
I was a bit concerned at first about the possibility of water in the toon (bought it used) then realized that the bottom paint on the port toon goes up a bit higher, so it’s always been like that.
It seems to level out fine when underway.
New Sylvan leans 2" to starboard at rest & underway
Re: New Sylvan leans 2" to starboard at rest & underway
Well, if you can’t tell, it doesn’t bother me, but it is less than the two inches noted by the OP.Henpecked wrote: ↑Wed Oct 03, 2018 9:16 pmMaybe they will provide "pin striping" to hide the difference.Rick McC. wrote: ↑Wed Oct 03, 2018 7:57 pmOur Bentley sits deeper on the port side, as the fuel tank is located at that rear corner of the boat.
After all; “physics is physics.”.
I would be a little upset in that the tank should be center mounted if possible. That makes you carry 175 pounds or so of beer on the starboard side to get a level ride!
2018 SouthBay 525RS3.0
Yamaha 250
Yamaha 250
And you see a problem with that?
