1983 Playcraft 28ft Project
Hello! So I have this big ole pontoon project and I plan on making it sort of a dual purpose boat, part serious fishing guide quality boat \ family pleasure boat. In the end I plan on having a new 100HP Honda outboard, maybe a tri-toon, maybe just a pod w/fuel and a transom. I plan on making it a center console boat with a 50 gallon bait tank on board (I already have one). I know I need a large livewell (around 80 gallons) but I'm not sure what to build it out of, or where to place it. I also plan on having a loading ramp in front, similar to a ramp on a large uhaul truck. I might make or buy some T-tops but I also need at least one bimini top, maybe two (one in front and one in back of the center console) I wish I could figure a way to have a swim deck like some boats have but as of yet this eludes me. This is all just a general idea of what I have in mind, I'm far from having the cash on hand to make it happen right away. A few more facts some may be interested in, I traded a utility trailer for the boat (had $400 in that) and gave the motor and outdrive away cause it appeared to be locked up, and I have a couple people interested in that big hard top so I should *EDIT* (did get $250) get a couple hundred dollars out of that, making my total investment under $400 (I did drive quite a ways to get it, and had to work on the trailer a bit to get it road ready)
Going forward I ask for any and all advice, and I enjoy checking out you guys boats and builds as well.
- resizetest3.jpg (1.12 MiB) Viewed 203526 times
- resizetest2.jpg (854.3 KiB) Viewed 203526 times
- resizetest1.jpg (1.05 MiB) Viewed 203526 times
Re: 1983 Playcraft 28ft Project
Why get rid of the hardtop? Only to replace it w/t-top and 2 biminis? Build your center console and have a support system (like a t-top) to hold center of hardtop. This will let you remove the 2 center supports and give you a wide open area to fish with only 4 corner supports. If you add 2 biminis you will have a lot less fishable space. And your not going to have an 8ft wide t-top, it would crack the tubes from stress. And that would leave a lot a folks wet with 3 covers not connected or flush to each other.
I would love to have a longer hardtop for our use
Welcome and keep the pictures coming
On one hand I do really like the hard top for family use, but I do some serious fishing and a t-top would give me some cover without hindering fishing so much (I'd remove the bimini's for a fishing trip). I attached a pic of my last pontoon (with almost no furniture) showing my fishing rods in use. In Oklahoma we're allowed 7 rods per person, and I expect I'll put rod holders all around this new build as well.
- resize4.jpg (1.39 MiB) Viewed 203511 times
You like fish tacos
Got a god fried coating recipe?
What fish you go after?
Catfish, specifically blue cats. Just about any mix will work I usually add some cayenne. Bass pro sells some that is good. We do like fish tacos but I prefer to eat it as I fry it lol
I fish all year but the family only likes going in nice weather, my last boat I only had one Bimini and only used it in the summer, often when the sun went down I'd take it off and put it in the back of my truck at the ramp.
To be honest I'm not sure I want any permanent top, but the t-tops could be useful in multiple ways, and when its raining it'd be nice to stand under, plus I have in mind a plexiglass windshield of some sort, still not sure about that.
I've been thinking a lot about how I'm going to build this thing and I have a question for any and all...I'm thinking I'll run most electricity through a fuse panel with a Main Power switch...I've seen so many boats with a ton of connections at the battery and they all have their own inline fuse, is this what most people do?
abrasivereshaping
I could see you doing a tritoon conversion with center console and livewells front and back. Rods racks along the fencing. Maybe the center toon would have storage for rods and tackle...just my .02
I like your assessment, hope I can do pretty much that exact idea, one question, does everyone plumb their water supply from the back of a toon or is there another way?abrasivereshaping wrote: ↑Tue Feb 11, 2020 8:56 amI could see you doing a tritoon conversion with center console and livewells front and back. Rods racks along the fencing. Maybe the center toon would have storage for rods and tackle...just my .02![]()
Back of pontoon gives you mount out of water turbulence. An aluminum bracket glued on with 3M 5200, ain't coming off....ever...well, by itself.
The back off tube will join it.
When I get around to ours, I plan 1 big cable fused at battery to a distribution under console. From there to everything else. Only other wire on battery/batteries will be to starter.
mine's from rear...PaulinOK wrote: ↑Tue Feb 11, 2020 1:46 pmI like your assessment, hope I can do pretty much that exact idea, one question, does everyone plumb their water supply from the back of a toon or is there another way?abrasivereshaping wrote: ↑Tue Feb 11, 2020 8:56 amI could see you doing a tritoon conversion with center console and livewells front and back. Rods racks along the fencing. Maybe the center toon would have storage for rods and tackle...just my .02![]()
- SAM_2920.JPG (253.23 KiB) Viewed 203425 times
I'll have any bracket welded on, but I agree on using a fuse panel.bansil wrote: ↑Wed Feb 12, 2020 5:21 pmBack of pontoon gives you mount out of water turbulence. An aluminum bracket glued on with 3M 5200, ain't coming off....ever...well, by itself.
Yes that's what I've seen the most, I'll probably use the same thing, just wish I didn't have to plumb it so far as my livewell will be towards the front I imagine.curtiscapk wrote: ↑Thu Feb 13, 2020 12:16 pmmine's from rear...PaulinOK wrote: ↑Tue Feb 11, 2020 1:46 pmI like your assessment, hope I can do pretty much that exact idea, one question, does everyone plumb their water supply from the back of a toon or is there another way?abrasivereshaping wrote: ↑Tue Feb 11, 2020 8:56 amI could see you doing a tritoon conversion with center console and livewells front and back. Rods racks along the fencing. Maybe the center toon would have storage for rods and tackle...just my .02![]()
Now if you want exchange water while stopped and fishing, a tube drop straight down would work.
Maybe a simple 4 ft pc of 1/4x1 metal with a hose and screen that can pivot into the water , so say 3ft under boat 1ft thru floor.
Make the part above deck with an angle in it so when metal/hose/screen etc is flat against bottom of boat handle still sticks up to grab it?
If you need ms paint I can do tomorrow at work on a computer
make the pivot at the level of the deck
I've thought about something like this in a couple different ways, one just use square tubing but angle it towards the front of the boat, of course it would only fill when moving forwards ( and you'd have to use a raised inlet tube to keep if from draining the livewell) or two, and much more complicated...also assuming I add a third pontoon, build a pump mount inside the middle log, a small area that would be under the waterline and plumb it up through the log to the livewell....but that's just not feasible really, to many concerns on several levels.bansil wrote: ↑Wed Feb 19, 2020 5:11 pmNow if you want exchange water while stopped and fishing, a tube drop straight down would work.
water pump.jpg make the pivot at the level of the deck
I am designing a livewell box for my boat that will more than likely take water from the rear of a pontoon, will filter said water and also be able to recirculate, aerate and constantly filter, much like my bait tank, but its all just an idea at the moment.
Today I got down to the decking, also tore into it a bit to see how hard taking it down to the bare frame might be, and it looks tedious lol. That back part is fiberglass and I'll have to remove the trailer before I can go to much farther, which brings me to a great question for you guys.... Do you buy something to put under your toons while its off the trailer or build some stands? I was thinking I'd build a couple for the rear of the toons and just use regular jack stands for the front? I'm not sure how much support it needs?
- resize7.jpg (1.27 MiB) Viewed 203307 times
- resize6.jpg (1.11 MiB) Viewed 203307 times
- resize5.jpg (1.13 MiB) Viewed 203307 times
- resize10.jpg (1.05 MiB) Viewed 203307 times
- resize9.jpg (1.05 MiB) Viewed 203307 times
- resize8.jpg (1.26 MiB) Viewed 203307 times
Heck, seenum sitting on crib blocks, 4x4's and even used tires...stable and level is all you need and the level thing is up to you. As long as a beer can can't slide off...level enough
