Voyager rebuild
3Sheets
Voyager rebuild
#1 Post by 3Sheets » Wed Apr 15, 2020 1:30 pm
First post here. I have done a lot of reading and have found the documentation here to be very helpful. To all that have shared your experiences and lessons, thank you.
I am rebuilding my Voyager 21VS and need to replace the plastic recesses where my docking and navigation lights are mounted. I have looked for them at several suppliers for pontoon items and cant find them. Before I have them custom fab'd I was wondering if anyone has any suggestions on where else I might look to find these?
Thanks in advance!
Scott
Aurora, TX
Voyager 21VS
Century 2600
Re: Voyager rebuild
#2 Post by bansil » Wed Apr 15, 2020 4:38 pm
:tassles
Welcome, I guess biggest questions are:
1 ) how deep are pockets for custom
2 ) how good do you want it to look
3 ) how handy are you
I would say...----it, replace cutout with sheetmetal and mount 2 more lights to it
Now, maybe look at some new boats and buy factory replacement parts and retro fit????? Most all have thos corner mounts
steve1313
Re: Voyager rebuild
#3 Post by steve1313 » Thu Apr 16, 2020 3:00 am
I agree with Bansil. Remove the plastic recess and just bend a piece of metal over it. Then add a surface mount nav light and an LED docking light.
3Sheets
Re: Voyager rebuild
#4 Post by 3Sheets » Thu Apr 16, 2020 5:43 am
Flush mount is the backup plan.
Wondering if they could be 3D Printed...
Aurora, TX
Voyager 21VS
Century 2600
TWB
Re: Voyager rebuild
#5 Post by TWB » Thu Apr 16, 2020 7:43 am
Welcome to the group!
Have to agree with the others. Are you replacing the fence aluminum as part of your rebuild? If so, just panel it in flat and surface mount or deck mount the lighting.
:2cents
-Paul
Paul & Michele
2003 Mercury 75hp
3Sheets
Re: Voyager rebuild
#6 Post by 3Sheets » Thu Apr 16, 2020 8:34 am
Trying to NOT replace the fence.
Aurora, TX
Voyager 21VS
Century 2600
Re: Voyager rebuild
#7 Post by curtiscapk » Thu Apr 16, 2020 8:36 am
I've seen them on a site i'm looking as I have time 8)
Re: Voyager rebuild
#8 Post by bansil » Thu Apr 16, 2020 4:11 pm
They would have to be abs printed to hold up to weather and uv (non exotic printing stuff excluded) and even then I dont know how they would handle the flex :donno
Maybe use acetone vapor to smooth them and remove exterior flaws...
3Sheets
Re: Voyager rebuild
#9 Post by 3Sheets » Fri Apr 17, 2020 6:06 am
@ bansil - the 3D shop I contacted can run it in ABS or PC (I assume poly carb) The price they quoted for the printing itself seems relatively reasonable but the 3D modeling set up fee makes it a pretty expensive option. ($250 setup, $60 - $150 ea to print)
Aurora, TX
Voyager 21VS
Century 2600
TWB
Re: Voyager rebuild
#10 Post by TWB » Fri Apr 17, 2020 8:09 am
Ouch! $250 for set up. I guess that's some of that "paying-for-that-guy's-knowledge" shit. Good luck with that.
Paul & Michele
2003 Mercury 75hp
3Sheets
Re: Voyager rebuild
#11 Post by 3Sheets » Mon Apr 20, 2020 8:37 am
Got all the old deck off of her over the weekend.
deck removed.jpg (896.29 KiB) Viewed 185134 times
Aurora, TX
Voyager 21VS
Century 2600
3Sheets
Re: Voyager rebuild
#12 Post by 3Sheets » Mon Apr 20, 2020 8:40 am
Found a problem when we opened her up. Time for a new steering cable.
Aurora, TX
Voyager 21VS
Century 2600
TWB
Re: Voyager rebuild
#13 Post by TWB » Mon Apr 20, 2020 9:59 am
Ouch! I went through the same problem - mine blew out! Fortunately you are down to the frame. It will be much easier to replace.
Paul & Michele
2003 Mercury 75hp
3Sheets
Re: Voyager rebuild
#14 Post by 3Sheets » Mon Apr 20, 2020 2:38 pm
Does anyone have tan furniture that has also put down vinyl flooring? Care to share which color / style flooring you chose and pics if you have them?
Im planning on gray woven pattern. Felt like tan would be too much tan. But pics from someone who has gone before me would be nice to see.
TIA
Aurora, TX
Voyager 21VS
Century 2600
TWB
Re: Voyager rebuild
#15 Post by TWB » Tue Apr 21, 2020 7:03 am
Two weeks ago. Still in rebuild mode. Ivory with Beige and Tan. Tan vinyl.
We offset the "tan" colors with blue fencing and blue biminis.
Seats 1.png (597.28 KiB) Viewed 185109 times
Paul & Michele
2003 Mercury 75hp
