Front edge of toons damaged....what the creative fix?
JV74
Re: Front edge of toons damaged....what the creative fix?
#16 Post by JV74 » Fri Apr 24, 2020 8:47 am
Ha! Ya a single man can go with the sharks teeth.....but I have the admiral to deal with.....
Those rubber things u included a pic of......where would I purchase those if I go that route?
steve1313
#17 Post by steve1313 » Fri Apr 24, 2020 9:00 am
Amazon - Just search for sheet metal edging
JV74
#18 Post by JV74 » Fri Apr 24, 2020 9:28 am
Thanks!
#19 Post by bansil » Sun Apr 26, 2020 7:22 am
:prayer
:boobies3 :tassles :boobies3
Ooo...ooh.I got an idea! Lets combine all our ideas...glue some shark teeth on the crinkled metal and make up a story about pirates and sharks....kinda like shark'nado meets somolian drug lords...chicks dig scars :mrgreen:
JV74
#20 Post by JV74 » Sun Apr 26, 2020 7:30 am
Ya know it would be cool to have the teeth hang down vs a sticker that is flat.........it would look like a sharks mouth coming straight at ya........hmmmmmm. Maybe I can find some rubber shark heads and just stick em on there........hmmmmmm the options are endless
Bamby
#21 Post by Bamby » Sun Apr 26, 2020 8:54 am
If you were to gather some cement blocks for instance and built up a table of sorts from the driveway up to the damage on the toons and use it as a dolly as you drive the aluminum against it to straighten it. This would allow each blow to be far more efficient because of a lot less loss to inefficiency. With the trailer jack being right there to help in elevation adjustments keeping everything snug so each blow is as efficient as could be a person could likely make pretty short work of it.
JV74
#22 Post by JV74 » Sun Apr 26, 2020 10:17 am
Winner!!!!!!! good suggestion...........I need to use the ground as my friend and build up to it.....then I can hammer away.......thanks
#23 Post by bansil » Sun Apr 26, 2020 3:11 pm
:canewave
I want a link to rubber shark heads if you find them....that could be intertaining....just saying...ugh..you know. .for a friend .. :mrgreen:
JV74
#24 Post by JV74 » Sun Apr 26, 2020 3:36 pm
#25 Post by bansil » Mon Apr 27, 2020 9:33 am
:happy
JV74
#26 Post by JV74 » Mon Apr 27, 2020 5:37 pm
Today I used a 3lb sledge hammer as my dolly and a regular hammer as a regular hammer ;) I had no idea what I was doing but actually was able to make a curved shape. Now the only thing left is the jagged edge which a soft piece of aluminum could be shaped just over the lip and through bolted.....still working it out.....
#27 Post by bansil » Tue Apr 28, 2020 2:02 am
Split a pc of black rubber gas line and slip it over?
JV74
#28 Post by JV74 » Tue Apr 28, 2020 6:43 am
I will take a better pic of it today,,,,the damage is about 2" deep.......so whatever is used to cover needs to have some depth
JV74
#29 Post by JV74 » Tue Apr 28, 2020 5:53 pm
toon damage.jpg (114.11 KiB) Viewed 7825 times
here she is......
