Cover support
Cover support
#1 Post by curtiscapk » Mon Oct 05, 2020 12:34 pm
So I've been dealing with different ways to support my cover. Everyone has kind of worked or kinda failed. I was using 2x4's and cover poles last. This usually worked but strong enough winds would knock them over. Resulting in torn cover.
I came up with what I hope is the final solution. I believe bits and pieces I got from different posts here. I used electrical conduit T's and brackets. I got the frame up but ran out of time to put the cover on. We're going out for a tree color run Saturday and no rain in the forecast.
Having the brackets on all three rails should keep fore and aft movement to nothing. It seemed to take quite a bit of weight from me pushing on the top of frame. I'm close enough to boat now I can check it after any big rain or snow storm.
Let me know what you think...
20201003_162418 (Medium).jpg (152.57 KiB) Viewed 104699 times
20201003_162414 (Medium).jpg (120.81 KiB) Viewed 104699 times
20201003_162226 (Medium).jpg (192.5 KiB) Viewed 104699 times
20201003_152531 (Medium).jpg (180.43 KiB) Viewed 104699 times
20201003_152524 (Medium).jpg (147.97 KiB) Viewed 104699 times
20201003_150800 (Medium).jpg (287.08 KiB) Viewed 104699 times
20201003_150648 (Medium).jpg (395.33 KiB) Viewed 104699 times
20201003_150544 (Medium).jpg (175.42 KiB) Viewed 104699 times
20201003_142417 (Medium).jpg (82.8 KiB) Viewed 104699 times
20201003_142412 (Medium).jpg (137.44 KiB) Viewed 104699 times
onlybillhere
Re: Cover support
#2 Post by onlybillhere » Tue Oct 06, 2020 7:36 am
nice! i did almost the same exact thing, I used pvc also for my cover but my cover is designed for an rv so it's a little heavier, combine that with the heat here in Florida and it didn't take long for the pvc to start sagging. I had some metal conduit that I used instead, bent it, and works great.
60HP Mercury 2 stroke
It's new! to me
Re: Cover support
#3 Post by curtiscapk » Tue Oct 06, 2020 7:41 am
This is what I did with 2x4's... hopefully new support stays up better with no rips!
Re: Cover support
#4 Post by ROLAND » Wed Oct 07, 2020 1:40 am
Craig, that new cover support system you put on your boat is sweet.. looks like it took a bit of work and I'm assuming you would just leave all the attached pvc right where it is when you take the boat out.. Don't think I'd want to take it all apart everytime I wanted to take the boat out... looks good. Def. better than the poles and 2x4's you were using...
Marc K
Re: Cover support
#5 Post by Marc K » Wed Oct 07, 2020 4:02 am
Interesting idea. I would think that it would do the job.
Re: Cover support
#6 Post by curtiscapk » Wed Oct 07, 2020 6:25 am
yep plan is to pop one pole at the T of each side and leave all poles at storage spot then reassemble when we return. Before we would put the cover on first then do the 2x4's. The idea now is support first then cover. We'll see how it goes Saturday... :donno
Steiner
Re: Cover support
#7 Post by Steiner » Wed Oct 07, 2020 6:45 am
Looks like it'll do the job.
Marc K
Re: Cover support
#8 Post by Marc K » Wed Oct 07, 2020 7:02 am
:lol3 :lol3
Re: Cover support
#9 Post by curtiscapk » Wed Oct 07, 2020 7:34 am
Now that shit is funny!!!!!!!!!!!!!!!!!!!! I'm not worried now!!!!!! :lol3 :lol3 :lol3 :lol3 :alright :alright :alright :alright
TWB
Re: Cover support
#10 Post by TWB » Thu Oct 08, 2020 9:18 am
I can see it now....... *dream music playing*
the floater.png (1.13 MiB) Viewed 104620 times
Paul & Michele
2003 Mercury 75hp
Re: Cover support
#11 Post by curtiscapk » Thu Oct 08, 2020 11:31 am
I'll take the 350!!!!!!!!!!!
Steiner
Re: Cover support
#12 Post by Steiner » Thu Oct 08, 2020 1:04 pm
Check the placard. I think the max you'd be rated for is 6.
Re: Cover support
#13 Post by curtiscapk » Thu Oct 08, 2020 1:12 pm
:deadhorse :deadhorse :deadhorse :deadhorse :deadhorse :deadhorse
Steiner
Re: Cover support
#14 Post by Steiner » Fri Oct 09, 2020 4:21 am
Old Seinfeld joke about going horseback riding: "Can't believe I got out of a vehicle with three hundred horsepower to get on an animal with one."
Marc K
Re: Cover support
#15 Post by Marc K » Fri Oct 09, 2020 4:55 am
Well done! :lol3
