Cover support
Re: Cover support
#16 Post by curtiscapk » Tue Nov 17, 2020 7:55 am
Well damn if it doesn't look like a covered Wagon TWB!
I decided to put vertical poles as well to keep it from sagging. I drilled a hole in the T-box to keep poles from slipping.
The inside pics are before I got it all tightened up. We'll see how she does!
20201115_151703 (Medium).jpg (172.83 KiB) Viewed 287579 times
20201115_151653 (Medium).jpg (181.56 KiB) Viewed 287579 times
20201115_145956 (Medium).jpg (139.98 KiB) Viewed 287579 times
20201115_145951 (Medium).jpg (147.41 KiB) Viewed 287579 times
20201115_145946 (Medium).jpg (120.16 KiB) Viewed 287579 times
20201115_143627 (Medium).jpg (388.86 KiB) Viewed 287579 times
TWB
Re: Cover support
#17 Post by TWB » Tue Nov 17, 2020 9:51 am
Nice job, Craig!
Just put the horses in the barn and you should be good through the off-season!
Just make sure Cookie turns off the chuckwagon stove or you could have a fire. That would attract injuns!
Paul & Michele
2003 Mercury 75hp
Re: Cover support
#18 Post by ROLAND » Wed Nov 18, 2020 3:16 am
Looks good Craig... nice job. Only place I'd be a little concerned about is at the front end, just inside the front gate.. From the pics looks like a low spot where water / snow could pool.. but maybe it's just the vantage point of the picture.
Marc K
Re: Cover support
#19 Post by Marc K » Wed Nov 18, 2020 6:27 am
What is this "snow" that you speak of? :biggrin2
TWB
Re: Cover support
#20 Post by TWB » Wed Nov 18, 2020 6:56 am
Yeah, we don't see much (if any) of that stuff down here.
Here you go, Marc, maybe this will help you:
snow
noun: snow; plural noun: snows
1. atmospheric water vapor frozen into ice crystals and falling in light white flakes or lying on the ground as a white layer.
"we were trudging through deep snow"
2. a mass of flickering white spots on a television or radar screen, caused by interference or a poor signal.
"all that they could pick up on their screens was snow"
:rofl :rofl
Paul & Michele
2003 Mercury 75hp
Re: Cover support
#21 Post by curtiscapk » Wed Nov 18, 2020 7:14 am
Thanks everyone! I did tighten that spot up some. It's close enough now I can check on it in 30 minutes.... We'll see.
Steiner
Re: Cover support
#22 Post by Steiner » Wed Nov 18, 2020 12:18 pm
Serviced mine last weekend and put the trailer on stands for the year. :cry: :cry: :cry:
Re: Cover support
#23 Post by curtiscapk » Tue Dec 01, 2020 2:44 pm
went to check on THE FLOATER after 40 -50 mph gusts and 1-2" of rain. Bow was perfect had some pooling in stern so pushed that out and tightened it all up back there. I may need to add another support there. All in all I think I nailed it!
20201128_112853 (Medium).jpg (164.06 KiB) Viewed 287508 times
20201128_112849 (Medium).jpg (123.53 KiB) Viewed 287508 times
Steiner
Re: Cover support
#24 Post by Steiner » Thu Dec 03, 2020 11:45 am
You can buy those vents like come on fitted boat covers for about $10 and the telescoping support poles aren't much more. Could put one in front and rear. I think they probably work better than those mushroom head standalone poles because the vent installs/clamps into the cover and then the pole inserts into the vent.
steve1313
Re: Cover support
#25 Post by steve1313 » Fri Dec 04, 2020 3:39 am
Yeah, adding some vents might not be a bad idea. Here's some of the products Steiner was referring to.
https://www.amazon.com/s?k=Vico+Marine+ ... nb_sb_noss
Re: Cover support
#26 Post by curtiscapk » Mon Jan 25, 2021 1:51 pm
took another visit to check on cover. We had 3-4" of snow over New Years when we were at the beach then some rain. THE FLOATER had 2! gallons of water pooled and an inch of ice. After all these years of thinking about how to build it and then to have the support work makes me smile.
20210124_103456 (Medium).jpg (134.61 KiB) Viewed 287423 times
20210124_103505 (Medium).jpg (159.88 KiB) Viewed 287423 times
20210124_103508 (Medium).jpg (650.54 KiB) Viewed 287423 times
TWB
Re: Cover support
#27 Post by TWB » Mon Jan 25, 2021 1:57 pm
WOOHOO! That has to be a great feeling. Glad it worked like you wanted. :nana :nana
-Paul
Paul & Michele
2003 Mercury 75hp
steve1313
Re: Cover support
#28 Post by steve1313 » Sat Feb 06, 2021 4:03 am
Curtis 1 - Mother Nature 0.
Good job!
Rick McC.
Re: Cover support
#29 Post by Rick McC. » Sun Apr 04, 2021 8:07 pm
That looks real good, Curtis.
Glad we don’t have to deal with that crap down here...
Re: Cover support
#30 Post by curtiscapk » Mon Apr 05, 2021 6:10 am
Thanks 2nd trip to check 3 weeks ago same thing totally supported. Finally found a winner!
20210306_114543 (Medium).jpg (104.4 KiB) Viewed 287275 times
20210306_114340 (Medium).jpg (240.84 KiB) Viewed 287275 times
20210306_114328 (Medium).jpg (296.49 KiB) Viewed 287275 times
