General question on timeline
Re: General question on timeline
Marina called and said my boat would be out of storage by the 10th. Going to set it on blocks so I can just back a trailer up and bring it home. So far, just the seat backs are planned. I added a GPS/Depth/Fish Finder to the job since it will be home and out of the water. Still deciding on the flooring if I'm going to tackle or not. Summer is coming, though it was <25F on my way into work this morning, it's still coming
Not sure if I should start a new thread or not. it's not a complete restoration, but i'm doing some seat repair and new floor. The boat didn't come out until yesterday so I got it in my driveway last night and started on it today. I can add a new bimini top to the mix too. It could have been replaced anyway, but the frame was fine. That was until I caught a branch turning it around at my house
New Bimini it is!
- thumbnail_IMG_2649.jpeg (218.54 KiB) Viewed 266179 times
- thumbnail_IMG_2646.jpeg (255.13 KiB) Viewed 266179 times
I did about 7 weeks on mine before we could get it into the water. Down to the pontoons took a lot longer than anticipated, but the result was worth the effort. I worked mostly alone and would guess about 5 hrs a day 5 days a week.
I think you may be on the right track. If you don't want to lose any of your "boatable season", do the floor (deck and flooring) and then enough to be satisfied for the season. Some guys have done the flooring and used lawn chairs or wicker furniture for a while. Doing the deck and flooring will be tough enough!
I agree with Motor7, you'd be looking at 7 - 8 weeks of full rebuild if you worked on it pretty much everyday. Our rebuild took about 7 weeks with my wife and I working a few hours most everyday. Get it to a comfortably useable point and plan to do more as you can conveniently - like at the end of the season. Don't give up precious boating time lost in rebuild.
-Paul
-Paul
Paul & Michele
2003 Mercury 75hp
2003 Mercury 75hp
New at This
When we rebuilt on boat, we were on a tight budget so we rebuilt our furniture ourselves, made needed modification to the console and shortened rear bench and fence to add bathroom/changing room over the rear toon. The next thing was to build front seats, but after a few years of lawn furniture in front of the console we decided it works the best, gives you a lot of flexibility with arranging it, can put it in front of front fence if you want or leave it stacked up for more space. We still have a table with a 3 person bench with an opening into the changing room and a 2 person bench opposite it. Leaves plenty of room for trash can and can recycling can. We have a 24 footer, with a 50 horse Mercury on it, went to a 10- pitch prop last year and gained 5 mph(17 mph to 22 mph) and motor seems to rev/run better with 5 on board.
made some progress today
and how much of this has to come off?
Looking good! The nice thing is once you get this completed, everything starts going up not down.
Personally, depending on what flooring you're using (I don't remember, and I'm too lazy to read back now!), you might feel little bumps under it. It looks like you could probably sand off anything you can feel with a hand rub. Think Princess and the Pea.
-Paul
Paul & Michele
2003 Mercury 75hp
2003 Mercury 75hp
I'm using a padded vinyl says it's 1/4 inch thick. I hope it's a comfy floor, it will get my wife out on the boat more often
https://www.marinevinylfabric.com/produ ... yQQAvD_BwE
and BTW, the deck is about 39" which is pretty much the same as my municipality issued garbage can as well. The "tip the helm off on its side method" worked great
Flooring finally was shipped should be here tomorrow afternoon. Of course the weather isn't great for it here. Still a bit chilly and definitely not 65+ overnight. hoping to hit that during the day even. Probably going to wait for a nicer day near 70 and then tarp it and put some heaters underneath it to keep the temp up for the glue to cure for 24hours.
man, flooring was supposed to be here, then not, then pushed back and then there it was at my door Saturday morning. Of course Saturday would have been a great day to put it on, but plans were already made with Great Grandma and the newest great grand baby. Sunday was supposed to be 60 and rain again for the next 10 days basically. so I pushed it off.
Then I woke up Sunday and it was nice out, checked the weather and it was sun and 70's. Called my dad and said, "want to come over". Ended up being sun and mid 80's. Rain was in the forecast and 50's that evening so we quick put it down and tarp'd it well. I stuck some electric heaters underneath to keep temp up overnight. was 110 under that tarp for about 7 hours until it cooled and rained. The heaters kept it 70-72 under the pontoon all night and kept them on until 7 the next evening so glue had plenty of curing time.
went pretty well.
went pretty well.
wow, it's looking GREAT. Love that flooring... You'll have her lake ready in no time. Keep the pics coming.
Thanks, it does feel very nice and certainly easier to look at then that old carpet. Have to keep the kids off of it for now though, the want to get up there and dance LOL
One question, the fence was put on thru the floor and then thru the aluminum cross members on the bottom. I didn't pay any attention to length, and ordered a new fence bolt package from pontoonstuff.com. They're only 3.5" and meant to go thru fence and plywood only. I need about 5" to get thru aluminum crossbeams like they originally had it.
Most of my old bolts were good, but some were bent and 3-4 I snapped when removing the nut because it was bent, so the plan was just to replace them all, but I don't want to drill that many new holes in everything. I can't find a package of rail bolts that aren't the 3.5" standard, but i'm sure i can get some stainless 5.5" bolts same size and do it. Or would you just substitute the handful that broke for the 3.5 and drill a new hole and just attach in the plywood? I'm sure it's strong enough, but i'm not sure I want to put any more holes in the decking that werent' already there.
Check Lowes, they have an extensive SS hardware section. Get the 5", they may be bolt head not screw head....no big. I replaced all my fence bolts with those from Lowes. Using a big SS fender washer and going thru just plywood is probably ok though. Re-use as many as possible as those SS bolts are $$$$.wiread wrote: ↑Wed May 05, 2021 4:26 am
