Bimini top "birdbaths" -- is there a fix?
guy48065
#1 Post by guy48065 » Sat May 22, 2021 6:53 am
I just replaced my oem canopy with an aftermarket top from our favorite sponsor.
The top is stretched tight along the 4 edges but it's baggy in the center. Wind makes it billow up. Far worse is when it rains it forms heavy pools between the frame bows.
I think these universal tops are made to fit frames with a lot more arch than mine has.
Is there a fix anyone has found for this problem?
Mark
Rush Lake, Atlanta, MI
guy48065
Re: Bimini top "birdbaths" -- is there a fix?
#2 Post by guy48065 » Sun May 23, 2021 11:36 am
I'm the only one to experience this?
Mark
rbtnt
#3 Post by rbtnt » Sun May 23, 2021 3:42 pm
Try adding straps between the bars.
guy48065
#4 Post by guy48065 » Sun May 23, 2021 7:18 pm
What will that do?
Mark
steve1313
#5 Post by steve1313 » Mon May 24, 2021 2:19 am
You'll never get as good a fit with a univeral top versus a custom or direct OEM replacement. The design of that top will keep it taut front to back, but there's really nothing to keep it taut side to side. It's just not really the right canvas for your setup. I'd return it and get a custom top made, or reach out to the manufacturer and see if they can help.
Marc K
#6 Post by Marc K » Mon May 24, 2021 4:55 am
I have not had this happen. I bought a universal top and frame kit from Pontoon Stuff. The adjustable support poles let me really tighten up the canvas. Obviously, when I am underway the air underneath keeps the canvas lifted up, and water does not pool when drifting in light rain.
I have not tried it in a downpour so I do not know if it would pool like that. It very well might do the same thing? Since that would be a very rare thing for me, I would prop my telescoping boat hook under it to create a peak. Redneck? Yes, but we head for our covered boathouse if the rain gets heavy.
I bought this one late last year:
https://www.pontoonstuff.com/products/h ... d5a6&_ss=r
Marc
guy48065
#7 Post by guy48065 » Mon May 24, 2021 5:46 am
I guess I'm not all that surprised that it doesn't fit MY frame very well.
What DOES surprise me is that I've never read anyone comment on it before.
Fixed that.
Mark
TWB
#8 Post by TWB » Mon May 24, 2021 5:47 am
Here are a couple of observations based on my own slack problems - though not as pronounced as yours:
* Note the frame rail is in the portion of the sleeve closest to the center - providing no stretch. YELLOW ARROWS
* If you can push the frame arms so they are to the outer portion of the sleeves, or even centered it may provide some center stretch. BLUE ARROWS
* Depending on how tight the sides are, you may be able to loosen and slide the front rail arm up closer to the sleeve arm bracket - allowing the front to pull a small amount more downward. RED ARROW
Maybe this will give a little more stretch to the center of the top, but it may not be enough to totally fix your issue. As I say, that's a bit more than I've personally dealt with. I have a full boat (24') double bimini that zips together in the center.
:2cents
bimini slack.png (717.96 KiB) Viewed 18101 times
Paul & Michele
2003 Mercury 75hp
#9 Post by curtiscapk » Mon May 24, 2021 6:20 am
James just sent me a replacement top. I won't get it hooked up until June something with vacation coming. I'll let you know. But it does look like it could be adjusted. I have front struts on my oem one makes it a lot tighter.
20200905_140053 (Medium).jpg (182.28 KiB) Viewed 18100 times
guy48065
#10 Post by guy48065 » Mon May 24, 2021 12:14 pm
Craig your frame looks similar to mine--low arch--so I'm interested in how yours fits.
@TWB:
The tension on the top is what's pushing DOWN on the center bows and pushing them to the "inside" stops of the sleeves.
I couldn't budge them but I didn't try repositioning the pivots.
I don't think that will help but I'll try that this coming weekend when I'm there again.
My oem top had 2 sleeves for each bow, which possibly would permit a brace or even a ridge in the center but the centered sleeves on this top won't allow that option.
Mark
Rick McC.
#11 Post by Rick McC. » Mon May 24, 2021 8:14 pm
I’ve never had a problem like that with any Bimini top I’ve ever had, and this is the first time I’ve ever seen something like that...
TWB
#12 Post by TWB » Tue May 25, 2021 5:28 am
Hmmmm..... If the tension is already that great, you may not get any movement from moving the pivots. Usually, of course, the "droop" would be because of a lack of tension. If yours is that great, I got no clue (which is not out of the ordinary!). Sorry, man. :donno
Good luck.
Paul & Michele
2003 Mercury 75hp
guy48065
#13 Post by guy48065 » Tue May 25, 2021 7:36 am
I've seen many boats with the top material removed and the frame folded up (winter storage for example) and the four bows stack on top of each other evenly. Mine is also like that. I have a feeling the fabric tension at the corners of the bows will not allow me to raise the center 2 higher but I'll give it a try and see.
Mark
KPC
#14 Post by KPC » Wed May 26, 2021 5:48 am
bimini strap.jpg (156.21 KiB) Viewed 18013 times
Try shortening your front straps a bit. It should pull your top forward and take up the slack.
KPC
Rick McC.
#15 Post by Rick McC. » Sat May 29, 2021 8:11 pm
I don’t believe that I’ve ever seen a four bow top before where the inner bows weren’t the same size. I don’t think that top skin is made to fit that bow configuration...
