Do you know where I can find something like this
Kytoon
#1 Post by Kytoon » Sun Jun 13, 2021 10:34 am
Don't know what it's called or where to look for it.
Anyone know what it's called or where I can buy something similar.
fuel housing.jpg (726 KiB) Viewed 231570 times
Marc K
Re: Do you know where I can find something like this
#2 Post by Marc K » Sun Jun 13, 2021 5:05 pm
For fuel I assume? So I Googled it.
https://www.amazon.com/Gas-Fill-Boat/s? ... l+for+Boat
Kytoon
#3 Post by Kytoon » Sun Jun 13, 2021 5:58 pm
yes for fuel. Thank you. I should have been more specific. I was referring to the shroud.
#4 Post by bansil » Wed Jun 16, 2021 6:25 pm
That old, match hose to a new filler and just make a plate to mount it....chance of 100% mouth is slim to none.
Fiberglass and plastic is fragile and UV kicks its azz
gerard143
#5 Post by gerard143 » Sat Jul 17, 2021 8:33 pm
looks like someone installed that backwards ages ago. That trimmed outside edge of the square panel usually went against the mounting surface.
https://www.greatlakesskipper.com/searc ... fill+panel
Here is your closest bets at the moment. I might have a leftover real similar to yours. I'd have to check. I think I tossed them. I had about 6 of these. I custom painted a few and had a couple with clear coat runs and think I tossed them out.
Kytoon
#6 Post by Kytoon » Sun Jul 18, 2021 7:47 pm
Now that you say that I think your right. It is up side down. I moved into a different direction. More redneck. I have the hose sticking up in the air with a pop up gas lid/vent combo. Going to add more hose so it's out over the back of the boat and if the filler gets a little sloppy or not paying attention the overflow will not fall onto the carpet.
#7 Post by bansil » Wed Jul 21, 2021 7:32 pm
Def. Post pictures of diy redneck fix :wink:
gerard143
#8 Post by gerard143 » Tue Jul 27, 2021 11:23 am
