1989 Sun Tracker Party Barge 24DL into Tritoon build
abrasivereshaping
Re: 1989 Sun Tracker Party Barge 24DL into Tritoon build
#46 Post by abrasivereshaping » Fri Oct 01, 2021 3:58 pm
Got some time to play on the lake today for a few hours. We tried a couple of different props my buddy loaned me.
So we tried a Stainless 14 x 21p 3 blade and saw 37mph gps @ 5600rpm...if I tried to trim up the prop would let go. So we swapped that out for a Mercury Mirage Plus, which is a 14-3/4 x 21p 3 blade. Top speed was 44.9mph! :thumbsup Unfortunately my WOT RPM dropped to 5100-5200rpm. I think I need to raise the motor a bolt hole, I can't see the cavitation plate when running. This engine is a tad heavier than the 90hp Johnson :biggrin2
Hopefully with a few more props to try out and engine height adjustments I can get her to run a few more MPH's into the upper 40's with this 200hp Mercury!
I'll post pics on Monday, when I can shrink them down at he shop computer.
Cheers 🍻
abrasivereshaping
#47 Post by abrasivereshaping » Fri Oct 15, 2021 1:12 pm
Ok fellow Tooners...Here is the pic of my ALMOST 45 MPH! :alright Going to play with more props and motor height. Probably only get one maybe two more trips out. It's time to wrap up boating in Michigan.
44.9mph GPS.jpg (129.75 KiB) Viewed 203082 times
TWB
#48 Post by TWB » Mon Oct 18, 2021 5:29 am
I imagine in MI in a few more weeks, if you do that 45mph, they'll find you with your hand frozen to the wheel!
Paul & Michele
2003 Mercury 75hp
#49 Post by curtiscapk » Mon Oct 18, 2021 6:53 am
Awesome!!!!!!!!!!!!!!!
abrasivereshaping
#50 Post by abrasivereshaping » Mon Oct 18, 2021 8:25 am
I know, it get's cold fast up here!! I swear we need to move south, to warmer weather and extended boating season :biggrin2
abrasivereshaping
#51 Post by abrasivereshaping » Mon Oct 18, 2021 8:28 am
Thank you! It's been a fun project, just love the boat. Hopefully Bryden24SHP can chime in and tell me some more speed tips!
