help keeping logs clean to keep performance
tooning around
#1 Post by tooning around » Thu Jan 08, 2009 6:06 am
So how do you guys keep your log from all the stuff that keeps growing on the log , so I can keep my speed?
rockymax
Re: help keeping logs clean to keep performance
#2 Post by rockymax » Thu Jan 08, 2009 6:19 am
You must keep your boat in a wet slip like me. Algae always a big problem. I have my toons pressure cleaned 2-3 times a year. My Crest dealer is testing Aurora's VS721 to determine if it works as they claim. Mfg. says this product will keep growth off for a full season and it is evironmentally safe. Test results will not be complete until probably March. I am hoping for positive results.
23' Hurricane
250hp Yamaha
Madison, AL
Wheeler Lake (TN River)
#3 Post by HandymanHerb » Thu Jan 08, 2009 6:22 am
Mines on a trailer so I don't have to worry about that, But the few times I have left it in the water for a few days I would run around it in shallow water with a rag and remove it.
dockholiday
#4 Post by dockholiday » Thu Jan 08, 2009 9:33 am
I used SOS/Brillo pads on my old toon when it was kept in the water, worked well. I am sure the neighbors wouldn't have liked it very much especially the environmentalist.
WaltF
#5 Post by WaltF » Thu Jan 08, 2009 11:26 am
Ive got a long handled floating brush.
I just float around the tubes, with a brew in hand, and scrub away at em every once n awhile....
Colorado Springs, CO.
tooning around
#6 Post by tooning around » Thu Jan 08, 2009 2:30 pm
OK, thats good for the out side , what about the inside of a strake? or inside of the logs 3 log.?Thanks .
#7 Post by HandymanHerb » Thu Jan 08, 2009 3:26 pm
I have a girl that comes in and takes care of the inside of my log, she uses a suction device and does a great job.
paulangelo
#8 Post by paulangelo » Thu Jan 08, 2009 4:38 pm
tooning around wrote:OK, thats good for the out side , what about the inside of a strake? or inside of the logs 3 log.?Thanks .
I don't think inside the strake would make any difference in speed for you. inside the logs for a triple toon (like I have also) On a relativly calm day, you can also go under the boat and rub them down. Always a good idea to have a spotter. i use the green scotch pads adn it really doesn't take a long time. plus, it's fun to get in the water and cool off.
#9 Post by badmoonrising » Thu Jan 08, 2009 7:21 pm
Antifouling paint prevents 90 percent of marine growth. That, combined with a light bottom scrubbing every few weeks when the water temp allows me to jump in the water keeps my 'toons clean.
Antifouling's not just for saltwater environments either.
Beats any product claiming that they prevent marine growth, I've seen none that live up to their claims. Growth inside of the strakes (my boat doesn't have or need them), isn't going to effect perfromance in any way, besides most marine growth needs sunlight to grow. It's dark enough inside of hollow strakes to prevent it from getting out of control.
#10 Post by HandymanHerb » Thu Jan 08, 2009 9:35 pm
I remember one time I had the kids out fishing, and the fish stopped biting where we were, so we decided to move , so here I am at my top speed of 16 mph and I hear this tap, tap , tapping, I was thinking what could that be when I remembered the stringer of fish tied to the front so that means their fins were tapping on my toons, so I stopped right away and I had scales all over, you don't want fish to tap his fins on your toon's for sure , just make them a mess.
:tofunny :tofunny :tofunny :tofunny
sdhawk
#11 Post by sdhawk » Thu Jan 08, 2009 9:48 pm
I found this site a while back and was curious enough to contact them. The unit for my boat was a little over $2000.00. For algae prevention you add chemicals to the water. They sale them or you can buy some from a pool store. I was concerned if there would be any reaction of the chemicals with the aluminum tubes. Plus how tuff are the inflatable sides.
Here is the site:
http://www.boatbunkers.com/
sdhawk
Calvert City, KY.
By Kentucky Lake-Just down the road from Possum Trot
My buddies pictured here are Sparky & Skipper.
2007 G3 LX322DLX (Cruise) 3 Tube
150 Yamaha 4Stroke
#12 Post by HandymanHerb » Thu Jan 08, 2009 10:06 pm
Hadn't seen that one before, so your parking your boat in a floating swiming pool, and I guess you put something in there to stop groth on the toons.
So I guess it must be be easy to drive the boat in and out of
tooning around
#13 Post by tooning around » Fri Jan 09, 2009 5:59 am
That is a new 1 for me. if you could ,how can a person show a photo so you can see what I mean?
mikeherb
#14 Post by mikeherb » Fri Jan 09, 2009 10:00 am
I also wipe my toons down in shallow water every other time I'm in the boat.
But, I also pull my boat out in mid summer, take it home and give it a thorough cleaning. I use wheel and spoke cleaner diluted at 50% and power wash it off. My toons are not polished and never will be...not enought return for the effort.
BMR, can you tell me more about the paint you mentioned? Is this like paint on a hull?
Dan
#15 Post by badmoonrising » Fri Jan 09, 2009 10:15 am
Same, but since you are applying it to aluminum and alot of bottom paint contains copper, you have to apply a barrier coat first.
Copper bottom paint actually accelerates corrosion on aluminum hulls, unfortunately it's the most effective in preventing marine growth.
My marina did it for me the first season, I touched it up last spring and will do it again for another season before doing another total repaint.
I used Interlux Primicon barrier coat followed by Interlux Micron CSC black.
