Ron Burgundy
#16
Post
by Ron Burgundy » Tue Jun 21, 2011 3:43 pm
PlaynDoc wrote:Check your trailer tire pressure. Once you find how messed up that is, you'll forget all about the light.
Huuuhhh...ummm, I don't have a trailer.
#17
Post
by badmoonrising » Tue Jun 21, 2011 8:46 pm
You'll want to check for 12v at the center and ground as shown below. I'm betting that the socket just needs to be cleaned though. Little bit of sandpaper will do..
When you put the light cover back on, there should be a metal contact inside. Make sure that lines up and touched the (-) contact on the base.
- dscn4140p.jpg (101.71 KiB) Viewed 1243 times
Ron Burgundy
#18
Post
by Ron Burgundy » Wed Jun 22, 2011 3:52 pm
Thanks BMR. I'm going to try to get over to the boat tomorrow, and give it a shot.
Ron Burgundy
#19
Post
by Ron Burgundy » Thu Jul 21, 2011 6:37 pm
badmoonrising wrote:You'll want to check for 12v at the center and ground as shown below. I'm betting that the socket just needs to be cleaned though. Little bit of sandpaper will do..
Got it to work!!! Let there be light. Time for some night fishin' or sunset drinkin'!! Thanks
#20
Post
by badmoonrising » Thu Jul 21, 2011 7:05 pm
Ron Burgundy
#21
Post
by Ron Burgundy » Thu Jul 21, 2011 7:58 pm
Maybe I can get a job with Bass Pro Shops.
