Tight steering
brianD
Location: Live in STL, Boat wherever there's enough water to not mess up a prop.
Tight steering
#1 Post by brianD » Tue Jan 10, 2012 10:56 am
I have a 27' landau, triple toon with a 225suzuki. I also have seastar assisted steering. Is it normal for the steering to get progressively harder as the speed increases? I'm used to a stern drive with power steering and I figured it would be different but at 30 it almost takes two hands to turn.
b
2006 Landau Excalibur 2700
225 Suzuki 4 stroke
2011 Bear tandem trailer
2011 3/4 ton Suburban
cwag911
Re: Tight steering
#2 Post by cwag911 » Tue Jan 10, 2012 12:18 pm
Do you mean Seastar Hydraulic steering? Our boat with the hydraulic steering was hard to turn and I installed the power assist unit and it's like driving a car with 1 finger. The dealer replaced the helm and hydraulic unit twice which didn't improve it. The power steering is the way to go but it's pricey. Every so often you can find them on Ebay.
Carl & Suzi
150 Honda 15x15p Enertia prop
Power assisted steering
Denver, NC Lake Norman
Pleiku, Vietnam 1971
GregF
Re: Tight steering
#3 Post by GregF » Tue Jan 10, 2012 1:31 pm
I assume at slow speed it is easy to turn? Is it the same both ways at 30?
1974 Harris
70 HP 4 stroke EFI Yamaha
Re: Tight steering
#4 Post by Bamaman » Tue Jan 10, 2012 2:09 pm
The Teleflex power steering pump to go with your SeaStar hydraulic steering system is $1,699 @ West Marine. Both Seastar and the power steering unit combined are mega-expensive items.
I'm sure they really feel fine, however.
captainjack
Re: Tight steering
#5 Post by captainjack » Tue Jan 10, 2012 5:39 pm
I had a 25 ft landau with a 225 honda on it, the turning sucked on that boat 1st warranty trip they said, the dealer I bought it from put the steering unit on upside down? So I paid them to correct it an never turned any easier. At one point while pulling people tubing the counsel came lose from the floor due to turning it so hard. My advise would be to find a dealer that sold those boats an see if those power units help or crack the middle toon? They are the hardest turning boats I have ever been in. I personally think those boats were not designed to turn at any speed at all. So I would want to know for sure this would cure the problem an not create another an waste money.
2008 Playcraft Extreme 2600
2008 300 Mercury Verado
2008 Bear Trailer
Iowa
GregF
Re: Tight steering
#6 Post by GregF » Tue Jan 10, 2012 6:36 pm
Get a bigger wheel
1974 Harris
dockholiday
Re: Tight steering
#7 Post by dockholiday » Wed Jan 11, 2012 10:31 pm
GregF wrote:Get a bigger wheel
Good suggestion. Young guys that is why the steering wheels were so large on the 50's cars. Funny don't remember my 57 chevy being that hard to steer, but then again I didn't miss air conditoning in the 60's either. Anything that took hp away was a no no so we were fast but sweated a lot.
GregF
Re: Tight steering
#8 Post by GregF » Thu Jan 12, 2012 11:27 am
Freddie Prinze said those tiny steering wheels were invented by Mexicans so it was easier to drive in handcuffs.
1974 Harris
Re: Tight steering
#9 Post by Bryden24shp » Tue Jan 24, 2012 1:59 pm
If you do have the power assisted steering, when you turn the steering wheel with the key on you will hear the servo's kick in and make a soft "wizzing' sound. Mine and several others with the power assist had a problem where it would kick out and steer hard. I added a 2nd ground wire to the pump and mounting bracket, making a wire shaped like a 'Y' then grounded it to the ground bar in the electrical distribution box. It fixed it permanently. And the all the other boats with the same problem. If you don't have the power assist, add it! Its easy to do and I have seen them advertised for under $850
Good luck with it!
Bryan
NH Tooner
Re: Tight steering
#10 Post by NH Tooner » Wed Jan 25, 2012 7:00 am
Bryden24shp wrote:If you do have the power assisted steering, when you turn the steering wheel with the key on you will hear the servo's kick in and make a soft "wizzing' sound. Mine and several others with the power assist had a problem where it would kick out and steer hard. I added a 2nd ground wire to the pump and mounting bracket, making a wire shaped like a 'Y' then grounded it to the ground bar in the electrical distribution box. It fixed it permanently. And the all the other boats with the same problem. If you don't have the power assist, add it! Its easy to do and I have seen them advertised for under $850
Good luck with it!
Bryan
I would like to install power assist in my new boat. where did you find it for that price?
Dave
Dave
2012 Homebuilt 28' Tritoon
225 hp Mercury
1993 24' Forester
50 hp mercury
cwag911
Re: Tight steering
#11 Post by cwag911 » Wed Jan 25, 2012 11:20 am
[/quote]
Dave[/quote]
I found one here for $800.00http://tampa.craigslist.org/psc/boa/2746892133.html
I paid $600.00 for mine on Craigslist.
Carl & Suzi
Re: Tight steering
#12 Post by Bryden24shp » Fri Jan 27, 2012 2:23 pm
Keep your eyes on Ebay.
rbiederwolf
Re: Tight steering
#13 Post by rbiederwolf » Fri Jan 27, 2012 3:44 pm
I have a 22 ft avalon 115hp with the baystar hydraulic steering. I have no difficulty turning whatsoever
2008 Yamaha 150hp
NH Tooner
Re: Tight steering
#14 Post by NH Tooner » Fri Jan 27, 2012 5:00 pm
Bryden24shp wrote:Keep your eyes on Ebay.
I dont think i would want to buy a used one. Just dont know what youre going to get. No real way of testing is there?
Dave
225 hp Mercury
1993 24' Forester
50 hp mercury
cwag911
Re: Tight steering
#15 Post by cwag911 » Fri Jan 27, 2012 7:04 pm
The one I bought on craigslist was used (from a stolen boat that was recovered) and was only 3 months old. The wiring harness was cut but I called Teleflex in Canada and they sent me a new one for free. It's been installed for 2 years now and no problems. I wish I would've done it sooner, what a difference.
I just found this one http://www.ebay.com/itm/Teleflex-Marine ... 35b8f29a6f
Carl & Suzi
