Docking Arms for Pontoons
Today I saw a pontoon boat in a slip being held by two arms that were mounted on the dock, and attached to the "eyelets" on the front of each pontoon. There were spring lines on the back. Does anyone know what these mounts are called, who sells them, and any experience with them? I would guess they might only work with a floating dock.
Debbie & Ray Lee
21' Sun Tracker Fishin' Barge
60 HP Mercury 4-Stroke BigFoot
Home City: Lancaster, Pennsylvania
Re: Docking Arms for Pontoons
Do you mean something like what is shown in this link: http://www.dockedge.com/products/list.a ... oring_armsraylee wrote:Today I saw a pontoon boat in a slip being held by two arms that were mounted on the dock, and attached to the "eyelets" on the front of each pontoon. There were spring lines on the back. Does anyone know what these mounts are called, who sells them, and any experience with them? I would guess they might only work with a floating dock.
2012 Princecraft 21-foot Fishing Pontoon
2012 Mercury 60HP Big Foot
No. The arms would be mounted on the dock at the bow, one for each pontoon. There is a "U" on the end of the arms that would fit over each side of the eyelet on the very front of the pontoon. A pin would go through the "U" and the eyelet to hold the boat. It keeps the boat from hitting the dock at the bow, and holds it from swaying side to side as well. The spring lines on the stern are mostly to prevent side to side, as the boat cannot move front to back due to the arms.
Debbie & Ray Lee
Are you sure these aren't home-made? I have never seen anything like that before.
22ft Premier 225RE PTX
150 Yamaha 4-Stroke
Lake Wylie, SC
150 Yamaha 4-Stroke
Lake Wylie, SC
Maybe something like this http://www.veveinc.com/shop/Positive-Lo ... D-584.html
WILD MAN
East Mississippi
East Mississippi
- brumbyvet.1044
I believe Overton's has the type of tie offs your asking about. Check out their web site.
Garmin 430S
Cherokee Lake, TN
Garmin 430S
Cherokee Lake, TN
Wake Watchers Mooring Systembrumbyvet.1044 wrote:I believe Overton's has the type of tie offs your asking about. Check out their web site.
The "arms" the WILD MAN found are a version of what I saw. The "arms" I saw were a single, adjustable arm instead of the "V", but the same idea. Thank you very much for all of the input and effort. I'll report on how they work if we decide to try them.
Debbie & Ray Lee
Davidlouisiana
Try " www.BackItUpAndForgetIt.com "
It's similar to what u say but it mounts to the boat by quick release for sacking at any dock.
Davidlouisiana wrote:Try " http://www.BackItUpAndForgetIt.com "
Look dangerous to hook up to me
