How do YOU fill your tank?
Re: How do YOU fill your tank?
yeah the shaker hose works great...been using it for years.
http://www.youtube.com/watch?v=LMPWdWAY9bo
Missouri dose
Funnels & siphons will work IF I park on the tank side of the dock. Otherwise I can't access the tank way out on the end of the log, no platform, no door, too far to reach. Kinda dumb placement IMO and I've noticed many newer 'toons around my lake with the same issue.
The 'toons with a (hidden) under-deck tank have nice long fill tubes with a screw-off cap placed at a convenient height.
Apparently nobody makes a fill tube that allows this convenience with tanks that have a screw cap. I called Moeller and was told nobody has ever asked but as far as they know it's not illegal to have a fill tube extension on a tank. I've found there are lots of take-off fill tubes & caps from PWC on eBay that could be adapted to my needs.
Mark
Rush Lake, Atlanta, MI
- katieclooney
For those of you that have the removable tank, do you ever experience leakage from it?
Ive been getting leakage, not a dripping leak, but enough to be noticeable.
That is a brand new tank ordered from the manufacture.
open the lid a few turns. the new portable fuel tanks do not have a vent. that is also why your tank is swollen in the picture. the leaking is from the pressure that is being built by the gas fumes that cannot vent and it needs to find a way out or the tank will break at some point.
My Happy place is on a boat at the lake with my kids!!
current boats:
1983 chaparral 235 XLC (restoration)
1977 playcraft p24 pontoon (parents own now I am the mechanic)
1975 skeeter hawk (on hold)
past boats:
this list will not fit!
current boats:
past boats:
- katieclooney
I don't think the tank is swollen. its always been a rounder tank when I bought it new.
Do you leave it vented ALL the time, even when driving? That tank has less than a quarter in it. even with that little of gas it will swell?
when I had the original cap on it I never tightened it all the way. but with my older motor the tank needs to be vented. I ended up changing the cap with one from an older tank that had a vent on it. I never close that vent either or about a hour later I can go outside and the tank is swollen.
current boats:
past boats:
current boats:
past boats:
- katieclooney
yea I have an old tank that came with the boat, that has the different cap and has a vent in the center. Then a brand new, with new EPA regulations on it, with this cap with no vent.
Its frustrating
Its frustrating
switch caps!!
current boats:
past boats:
current boats:
past boats:
- evinrude2stroke
Something like this. It has a vent on the top. I keep mine open all the time. Keep in mind I still had an incident of vapor lock where it stalled out on me. If it happens again I'm going to look for an old tank.katieclooney wrote:yea I have an old tank that came with the boat, that has the different cap and has a vent in the center. Then a brand new, with new EPA regulations on it, with this cap with no vent.
Its frustrating
http://www.ebay.com/itm/Moeller-2-Stage ... 6d&vxp=mtr
Dave
WE have a gas station at the entrance to our ramp makes it super easy!! Straight gas too!
- BearsDen.JPG (82.77 KiB) Viewed 2993 times
- katieclooney
I use both tanks so we can plug and play between the two.nathan wrote:switch caps!!
I might try to find a new cap for it.
look on craigslist for a cheap used tank that has a good cap. or ebay has some below is one
http://www.ebay.com/itm/Moeller-Mfg-305 ... 40&vxp=mtr
current boats:
past boats:
current boats:
past boats:
Someone mentioned a replacement spout for new gas cans. Here's one:
http://www.ruralking.com/ez-pour-replac ... t-kit.html
You can also search Utube for how to put a vent on the new cans using a tubeless wheel valve stem.
2008 Tracker 24' Party Barge
Mercury 60 hp Big Foot 4 stroke
2011 Ford F150 Ecoboost
Point 25
Owl Creek Cove
Table Rock Lake
Southwest Missouri
Point 25
Owl Creek Cove
Table Rock Lake
Southwest Missouri
Darn good idea! I suppose you take the core out and it's all set. One could also use the small stem to dribble a bit of gas out if you need it to "prime" a carb, a little unsafe solvent, etcTully wrote: You can also search Utube for how to put a vent on the new cans using a tubeless wheel valve stem.
Mark
