flag mount
Re: flag mount
BTW, a good place to get a large variety of flags is at http://www.united-states-flag.com/
Kenneth & Joy
Lake Conroe, Texas
2007 Bennington 2577RFSi
2006 Yamaha F225
Solas 14.25x17SS prop
Best ever top speed 69.2KPH
Lake Conroe, Texas
2006 Yamaha F225
- Mosnowman
Re: flag mount
I use the Overton's model when cruising...however when coving out or sloooow cruising I use this. The stand sldes under my back storage compartment and I set my 6 gallon spare gas tank on top of it for extra weight, though it would stay without it. I can then mount two full size flags on it. It works great!
BUSY LIVING...
Columbia Mo BZLIVN
Columbia Mo BZLIVN
Re: flag mount
Had wondered how I was going to mount my flags - but didn't want to spend $40 a pop for two "pontoon flag masts". Since I have a hardtop on my boat, using zip ties on the rear, and even front legs of the hardtiop (if I get crazy with flags....) is going to be this cheapskates answer.....OK Toon wrote:Hi went real hi-tech redneck for our flag mounts. I used 4 zip-ties on the back bimini post. I put 2 zip-ties on the post. Then I used the other 2 zip-ties to loop under the zip-ties on the post and then through the grommets on the flags. This allows the flags to "wave" in the breeze. I can get pictures if anyone wants to try this hi-tech approach
Thanks for the idea!!
1991 Harris Flotebote Sunliner "Laura's Leisure"
2020 Yamaha 115LB
Lake Jordan, Alabama
Retired U.S. Navy Spook
Vietnam '68-'70
[b]"Drinking Rum before 10 AM doesn't mean you're an alcoholic -
It means you're a Pirate!"[/b] :drink
2020 Yamaha 115LB
Vietnam '68-'70
Re: flag mount
I already had the flag and anchor light flag pole from my old boat. So i went the affordable route and got the PVC and hose clamps to hold the tube up.
Thanks, Mike
2000 Weeres Suntanner 20 | Mercury 50 2S | Shoreland'r Bunk
Re: flag mount
Heres how I did mine.
- 86Playcraft2000.jpg (82.43 KiB) Viewed 1028 times
- 86Playcraft2001.jpg (65.03 KiB) Viewed 1028 times
