Moving a carport
Re: Moving a carport
Just curios, Noticed the fence behind the cover is open. Will it stay that way and are you going to be able to come in that way? Is that a small church behind there?
I am on a corner lot and yes thats a church behind my lot and its a lot easier to back it in from their lot, You can see a bit of the lot in the new pic. I have talked to the pastor and he is ok with it and i plan on putting in a set of twin gates in the spring. In fact its a old and falling down privacy fence i am planing on replacing with chain link in the spring or summer.RcgTexas wrote:Just curios, Noticed the fence behind the cover is open. Will it stay that way and are you going to be able to come in that way? Is that a small church behind there?
this is how i pulled out the stakes
- chain rachet.JPG (395.07 KiB) Viewed 1250 times
Thought i would add one more pic, a lot of work but here is the end result
- in carport.JPG (285.64 KiB) Viewed 1164 times
That cover is going to be good. high enough to work under but low enough to keep "stuff" from flying in.
i can just walk under it, on the side i will bang my head.
Better that it is lower though, might stay cleaner, as in leaves and stuff.
