Gas tank's...and then there were two...
GregF
Re: Gas tank's...and then there were two...
#16 Post by GregF » Thu Mar 10, 2011 8:37 pm
It can, just be careful which port you use and put shutoff valves on each tank. The other choice is to just use a 3 way shutoff valve and a single port into the separator.
cbavier
#17 Post by cbavier » Thu Mar 10, 2011 8:55 pm
Ron I think I would try to pressurize it with low pressure and see if it really does leak. There is surely some kind of liquid soap. Maybe Auto Zone would know what you could put in the tank. Then pressurize it. It wouldn't take but about 3 or four pounds pressure I would think. Defiantly no more than six pounds. You don't want to blow it up. Just see where it's leaking. I had wondered why nobody made a tank that would fit in the pod like that. Then I found out they do make one. Defender I think sells them. They do come in different sizes because I remember the ad saying measure very carefully and it gave the Specs. I have the defender catalog if you want me to look. Just let me know.
Own-It-II
Chuck
50 HP Johnson
06 GMC Sierra Crew Cab
Roscommon, MI
GregF
#18 Post by GregF » Thu Mar 10, 2011 9:25 pm
You can get plenty of pressure for leak test with a vacuum cleaner on "blow".
spurhunter
#19 Post by spurhunter » Fri Mar 11, 2011 10:21 am
On my old Center console boat, it had in in-deck tank that the previous owner told me was no good and I was scared to use it. Drove the boat for 4 years with a red tank like yours. Then I just hooked up the old tank, dumped a can of Sea Foam in it, and a water seperator and ben using it for the last two+ years. (The boat is falling apart now, so I am pulling it to sell very soon.) :(
1985 Johnson 175 gas guzzler
2007 2500HD Duramax Z71
GregF
#20 Post by GregF » Fri Mar 11, 2011 11:30 am
Ron, while we are talking about rust (ref the hose clamp note), that filter in your water separator is going to rust out long before it is bad. I paint them with a couple coats of rustoleum before I install them. Do it over a couple days so the coats bake in well. Pay particular attention to the top between the gasket and the rim. Pull the rubber gasket out, mask off the inside to keep the paint out of the filter and shoot it.
The other thing is the base they screw into.
After 2 filter bases I got a stainless one. Hanging on the transom, getting splashed a lot, kills them in 5 years or so.
Ron Burgundy
#21 Post by Ron Burgundy » Fri Mar 11, 2011 5:17 pm
cbavier wrote: I have the defender catalog if you want me to look. Just let me know.
Thanks for the thought. I have a feeling the tank itself is okay, and water was getting in through somwhere else. The previous owner said it may even be condensation, because the bottom couple inces of the tank is submerged. If it turns out to be a bad tank I may take you up on that offer.
GregF wrote:The other choice is to just use a 3 way shutoff valve and a single port into the separator.
I would like to get a 3 way valve so I can easily switch between tanks, and just use one fuel/water seperator , and primer pump etc...
lakerunner696
#22 Post by lakerunner696 » Fri Mar 11, 2011 6:17 pm
My reference to 2 clamps per connection was to be sure nothing got through(water, air, etc).
2008 F150 Lariat Super Crew
Haul Rite trailer
#23 Post by badmoonrising » Sat Mar 12, 2011 12:30 pm
lakerunner696 wrote:My reference to 2 clamps per connection was to be sure nothing got through(water, air, etc).
You need 2 clamps per connection to meet USCG regs in permanent installed tanks anyway...
Ron Burgundy
#24 Post by Ron Burgundy » Sat Mar 12, 2011 2:26 pm
Is that two clamps side by side for a total of 4 clamps on one hose?
#25 Post by badmoonrising » Sat Mar 12, 2011 3:28 pm
Yep, two clamps at every fitting..
lakerunner696
#26 Post by lakerunner696 » Sat Mar 12, 2011 3:29 pm
Any where you have a connection you need 2 clamps, you put them next to each other
Haul Rite trailer
#27 Post by badmoonrising » Sat Mar 12, 2011 3:42 pm
Yeah..like so:
Ron Burgundy
#28 Post by Ron Burgundy » Sat Mar 12, 2011 3:45 pm
Good to know...looks like I am currently out of compliance... :nono
#29 Post by badmoonrising » Sat Mar 12, 2011 4:25 pm
Also when you buy clamps..make sure they are 100 percent stainless. There's alot of them that have plain steel screws with a stainless ring. In your climate, they'll corrode and break pretty quick. Bring a magnet to be sure :rofl :rofl :rofl
Seriously. I do...a boat builder friend of ours recommended I do so. Generally what's sold at marine stores is 100 percent while hardware stores, Lowes, Home Depot, etc. mix and match them.
justfloating
#30 Post by justfloating » Sun Mar 13, 2011 9:13 am
X2 on the magnet, there is no guessing involved. If it sticks you don't want it.
Clamps 002.JPG (53.75 KiB) Viewed 2262 times
