can it be this drastic?
Pontoon Really?
#1 Post by Pontoon Really? » Sat Sep 29, 2012 4:01 pm
I have a Sylvan RPT 8522 with a 150 Optimax. The boat has run great all year. I hane not used it in about a month. I could only top out at 28 mph. I usually run around 40 - 42 MPH.
Could the growth on the tunes slow me down that much?
Thanks in advance!!
BoatCop
Re: can it be this drastic?
#2 Post by BoatCop » Sat Sep 29, 2012 5:00 pm
What RPMs are you pulling, compared to prior runs?
Alan
2016 Chevy Tahoe
2009 GMC Sierra
2001 Jeep TJ Wrangler
1999 Southwind 34L MH
2 little Basset Hounds
GregF
#3 Post by GregF » Sat Sep 29, 2012 5:40 pm
What do the toons look like? If they are encrusted, it can easily rob that much speed.
slingshot
#4 Post by slingshot » Sat Sep 29, 2012 6:26 pm
Pontoon Really? wrote:I have a Sylvan RPT 8522 with a 150 Optimax. The boat has run great all year. I hane not used it in about a month. I could only top out at 28 mph. I usually run around 40 - 42 MPH.
Thanks in advance!!
Yes. Are you running in salt water? Is your bottom painted? As Greg asked, how does your bottom look? A few barnacles on your prop can cause huge losses.
2007, 2570 Crest LE II
Yamaha F150
gramps
#5 Post by gramps » Sat Sep 29, 2012 6:44 pm
Thanks in advance!!
I don't know about salt water but I would say no in freshwater. We let our boat sit for a few weeks if we are traveling and when we use it I really don't see any difference.
2012 Berkshire, 230cl Tritoon
150hp Mercury 4stroke
Road King Trailer
Towed with a Buick Enclave
sgpwayne
#6 Post by sgpwayne » Sun Sep 30, 2012 9:38 pm
sounds more like bad fuel to me. Were you using non ethanol gas?????
Wayne and Carla Taylor
Vanvouver, WA.
2005 Suntracker Bass Buggy
60 HP Mercury Big Foot 4 stroke
54# Motorguide trolling motor
2 Hummingbird Fish Finders
03 Dodge Ram 1500 2wd
OF COURSE I TALK TO MYSELF, SOMETIMES I NEED AN EXPERT OPINION
Texoma Toon
#7 Post by Texoma Toon » Mon Oct 01, 2012 3:40 am
Check your fuel filter too!
2007 G3 LX 22 Fish & Cruise
90 Hp Yammy
Dual Axle Trailer
robster
#8 Post by robster » Mon Oct 01, 2012 5:59 am
Algae growth slows our tritoon down 6-9 mph. after I scrape the algae off with a plastic paint scraper we gain 6-9 mph.
The_Hellbilly
#9 Post by The_Hellbilly » Mon Oct 01, 2012 8:10 am
Could be a leak in a log and now your toon is ALOT heavier. It happened to me.
2005 Voyager 22ft Tritoon
2004 Honda 135hp
Pontoon Really?
#10 Post by Pontoon Really? » Mon Oct 01, 2012 12:10 pm
BoatCop wrote:What RPMs are you pulling, compared to prior runs?
I am running 4800 RPM WOT. I have only lost 200 RPM. I did not think about the fuel - quite possible.
The logs are all scummed up......fresh water - dirty lake. I will have the tunes checked for leaks when I pull her out later this month.
Thanks to all!!
BobL
#11 Post by BobL » Mon Oct 01, 2012 2:29 pm
I keep my boat in the water (fresh) from March thru October. In Louisiana (think hot water), I have to scrape my toons at least 3 times a year and as I approach toon scraping time, I bet I lose close to 10mph in top end speed because of the growth. The boat performs like a PIG with all that growth on there.
Texoma Toon
#12 Post by Texoma Toon » Tue Oct 02, 2012 4:40 am
Thanks to all!!
4800 rpm is less than it should at wot. Shouldn't it be closer to 5500-6000? You may want to check your tac or your prop is not right for your toon......
90 Hp Yammy
Dual Axle Trailer
