Need to drill a couple of holes
In the side panels of my new 'toon. Mounting a rod holder. Looks like I need a 1/4 inch or a bit less in diameter. I've had thin sheet metal tear when drilling into it. Anything I need to know, before I start?
2013 Aqua Patio - 90 hp Honda. Retired, living on Houghton Lake, MI.
Re: Need to drill a couple of holes
These are perfect for drilling sheet metal, especially thin aluminum
http://www.lowes.com/ProductDisplay?par ... &cId=PDIO1
2010 150 HP Mercury Optimax
+1 on the Unibit.
Carl & Suzi
150 Honda 15x15p Enertia prop
Power assisted steering
Denver, NC Lake Norman
Pleiku, Vietnam 1971
Is there a reason why you are mounting to the panel rather than the railing?RJF wrote:In the side panels of my new 'toon. Mounting a rod holder. Looks like I need a 1/4 inch or a bit less in diameter. I've had thin sheet metal tear when drilling into it. Anything I need to know, before I start?
2011 Sweetwater 206F Sunrise
2011 60 HP Evinrude Etec
Humminbird 798SiHd
Boating on Moose, Pigeon, Lac St. Anne and Sask Landing
Humminbird 798SiHd
On mine I had the holders that bolted to the square rails. I didn't have to drill any holes and it let me move the rod holders to anywhere I wanted to move them. It's much better than drilling any holes. Mine came from Cabella's. $25 each
Own-It-II
Chuck
50 HP Johnson
06 GMC Sierra Crew Cab
Roscommon, MI
Chuck
50 HP Johnson
Roscommon, MI
- Capt Sully
use a center punch and a sharp bit, start slow
2012 Xcurison X23C
Yamaha 90 hp 4 stroke
Maritime mobile KD4LZL
Lake Allatoona, NW Ga.
FVC USCG Auxiliary
Vietnam 66 / 67
FVC USCG Auxiliary
Vietnam 66 / 67
cwag911 wrote:+1 on the Unibit.
+2
+1 on the bolt ons for the rails. I get my Cabela here in Ohio March 7th (taking the day from work lol). Thats going to be one of my 1st purchases...
B.S.BARge
Bodie & Stefanie
Central Ohio Lakes
2007 Chevy Sliverado Z71
Bodie & Stefanie
Central Ohio Lakes
+3, I use them on all my thin wall aluminum projects. Really work good for drilling the holes into underskinning goes super fast!badmoonrising wrote:cwag911 wrote:+1 on the Unibit.
+2
RonKMiller
Step drills are awesome, and you can get a 3 piece set at Horrible Freight for $12.99:
http://www.harborfreight.com/3-piece-ti ... 91616.html
Once you've used them you'll wonder how you ever lived without them...
RonKMiller wrote:Step drills are awesome, and you can get a 3 piece set at Horrible Freight for $12.99:
Thanks for the lead. I thought I had every tool in the World, and two of most of them. Never seen this drill before. I'm using the Cabela's mounts. On the starboard side, no problem - mounted it on the door. On port side, there is no door and no spot without the panel below the rail. Two holes is the only way I can think of to mount it.
- 640 X 480.jpg (252.74 KiB) Viewed 2928 times
