Throttle control box swap?
Darin
#1 Post by Darin » Sun Jul 14, 2013 5:05 pm
Do any of you guys know how to swap the handle around on this OMC throttle control box? The control was mounted to my old helm and I am installing a new helm and want to mount my control box on my rail so I wont be pushing and pulling on my new helm. I know it can be done but don't know how to get the handle off. I took out an allen head screw, thinking it may have been a set screw but the handle wont come off. I don't want to beat on it or put too much pressure on it and break the cast aluminum. Thanks.
Darin and Karri
Beaver lake Arkansas
guy48065
Re: Throttle control box swap?
#2 Post by guy48065 » Sun Jul 14, 2013 7:40 pm
That controller looks like it's meant to mount & operate only one way.
Mark
Rush Lake, Atlanta, MI
Darin
#3 Post by Darin » Mon Jul 15, 2013 6:24 pm
Nope it will work either way. I figured it out. You have to loosen the set screw then tap on the head of the screw with a hammer and punch to get the handle to release from the splines. I got it swapped and new cables installed on the controller end. Just need to mount it and run the cables to the motor.
Darin and Karri
guy48065
#4 Post by guy48065 » Tue Jul 16, 2013 7:09 pm
Good job! Even though the "back" had the opening for the lever, and countersunk mounting screw holes, I still thought that without the recess for mechanical stops the lever wouldn't work right on the reverse side. I'm glad it does. Controls are expensive :)
Mark
