Sealant
ezrollin
Sealant
#1 Post by ezrollin » Sat Feb 22, 2014 2:31 pm
What sealant did you use for your thru the transom motor support bolts, will silicon suffice ?
Re: Sealant
#2 Post by HandymanHerb » Sat Feb 22, 2014 2:41 pm
Doesn't mater since the bottom of most transoms have a big hole in the bottom to let water in and out, but silicone will help with wood rot around bolts
ezrollin
Re: Sealant
#3 Post by ezrollin » Sat Feb 22, 2014 2:57 pm
Yes,now that you mentioned it probably only splash water would be on those bolts. I did treat the bolt holes [5 on each side] holding the transom with a liberal coating of urethane,the bottom ones stay pretty wet.
playcat
Re: Sealant
#4 Post by playcat » Mon Feb 24, 2014 6:59 pm
I would coat the holes with thin epoxy and let cure completely. ream out the holes if need be, and seal with 3M 4200 polyurethane sealant
playcat
JC 266 TriToon
Kerr Reservoir, VA
fergusmj
Re: Sealant
#5 Post by fergusmj » Tue Feb 25, 2014 10:57 am
Just a quick thread hijack. I assume sealant isn't needed for the all aluminum transoms correct?
Ferg's Tritoon Build
