Pontoon Cleaners
woodrifters
Pontoon Cleaners
#1 Post by woodrifters » Mon Mar 10, 2014 4:27 am
New to the forum. Looking for the best options for tube cleaning. I have heard about Toon Brite but would like to consider others if there are anything better out there. Thanks
2014 Ford F150 XLT
2003 F250 Diesel 6.0 Super Crew
22 Ft Sun Catcher V22F
Yamaha 115HP
mgarvie
Re: Pontoon Cleaners
#2 Post by mgarvie » Mon Mar 10, 2014 5:45 am
NAPA Aluminum Brightener
#3 Post by Bamaman » Mon Mar 10, 2014 7:46 am
Either will work fine--spray on with pump up yard sprayer. Rinse with clean water.
The finish may be dull but clean. Restoring the shiny finish might require using a dual action polisher with a wool bonnet and a high quality metal/aluminum polish. (Mother's aluminum polish is not a good product for this use.)
Many use Sharkhide to maintain the shine, but the toons have to be completely clean of all black oxide. I find cleaning the toons with lacquer cleaner to remove the black oxide is 10x as much work as I want to do.
It only takes me 60-90 minutes 1x per year to polish three nose cones and the outsides of two toons.
pond tuuunes
#4 Post by pond tuuunes » Mon Mar 10, 2014 4:04 pm
sharkhide
photo (7).JPG (40.12 KiB) Viewed 2662 times
kiowacampers
#5 Post by kiowacampers » Wed Mar 12, 2014 11:35 am
We spent 2 days cleaning our toons inside and out with Streakmaster aluminum brightener. We've used this for 3 years and it's non toxic. I here a lot about sharkhide and will be investigating that.
Carol and Jesse (aka The Bickersons)
2006 Suntracker 32ft. Regency Signature Party Cruiser w/150hp Merc Optimax
2003 Ford F350 Diesel 6.0
11 ft. Quicksilver 330 Dinghy w/15hp Evinrude
A massive amount of dogs
In the middle of nowhere, Agate Colorado
robster
#6 Post by robster » Wed Mar 12, 2014 11:41 am
If you use JJ's Best be sure not to let it touch your anodized aluminum, it will remove the anodization, I can testify to that.
Cycleman07
#7 Post by Cycleman07 » Wed Mar 12, 2014 11:41 am
Sharkhide is a protectant. Once you get them clean put on a couple of coats of sharkhide and you should be waterline free for 3+ years. For leaning get some AC Coil cleaner at any autozone etc. and get to scrubbing.
Woody
#8 Post by Woody » Wed Mar 12, 2014 2:47 pm
Cycleman07 wrote:Sharkhide is a protectant.
Sharkhide also makes an excellent cleaner, and metal polish.
2019 Veranda 22 RFL 250SHO
Cycleman07
#9 Post by Cycleman07 » Wed Mar 12, 2014 6:40 pm
See, I learn something new everyday.
