Talon anchoring system
wijames
#1 Post by wijames » Fri May 09, 2014 12:44 pm
Has anyone installed a Minn Kota Talon anchor on their toon? How did you mount it? I've looked all over the Minn Kota sight and even contacted them for help but they don't seem to make a mount for pontoons. Any suggestions?
(old) 2000 Sylvan 20' Tritoon
Gonefishing
Re: Talon anchoring system
#2 Post by Gonefishing » Fri May 09, 2014 4:00 pm
There is a mount. It is a angle mount. Bolts to the floor at the rear. Check with them again. I have seen it on their websit when I was checking on getting one for my toon. But decided the price was not. Worth it. I purchased a shallow water anchor system. A lot cheaper and works great
Bob Jacksonville, Nc
2013 Excursion X23 RFC
2013 115 Yamaha
Pulled with a Ford King Ranch
Capt Sully
#3 Post by Capt Sully » Fri May 09, 2014 4:06 pm
Haven't seen that one, heres what I installed. A TRAC 35 made for pontoon mounting. It's electric with a remote control. Iv'e used it only one season so far and it works great and sure beats pulling on a rode. Push a button and it goes up or down. I can stay seated and don't even have to put my beer down. :drink Also it don't matter if you place it on the front or rear on a pontoon, works great.
Trac 35.jpg (111.19 KiB) Viewed 6052 times
2012 Xcurison X23C
Yamaha 90 hp 4 stroke
Maritime mobile KD4LZL
Lake Allatoona, NW Ga.
FVC USCG Auxiliary
Vietnam 66 / 67
chill'nthemost
#4 Post by chill'nthemost » Fri May 09, 2014 5:29 pm
Not only "beats pulling on a rope" but it would eliminate the hassle of spooling a rope after the ropes on deck. That's a nice setup. :thumbsup
killerkernrich
#5 Post by killerkernrich » Fri May 09, 2014 8:56 pm
whats on the end of that rope?
PLP Member
NRA member
UFC fan
Gonefishing
#6 Post by Gonefishing » Sat May 10, 2014 2:26 pm
This is what is use and it works great. Can be purchased from Bass Pro Sho
http://shop.stickitanchorpins.com
2013 115 Yamaha
Capt Sully
#7 Post by Capt Sully » Sat May 10, 2014 3:33 pm
killerkernrich wrote:whats on the end of that rope?
Why an anchor of course. :lol3 I'm using a 18lb river anchor here on the lake. It digs in just enough to hold but not too deep as a fortress would and easy for the motor to pull it up. Works great, I'm happy with it. They are making the gears on the motor out of metal now, before they were plastic and had some problems.
2012 Xcurison X23C
FVC USCG Auxiliary
Vietnam 66 / 67
hoosierhick
#8 Post by hoosierhick » Sat May 10, 2014 5:12 pm
Sully .Do you have any interference issues ?
killerkernrich
#9 Post by killerkernrich » Sat May 10, 2014 8:28 pm
I have a maybe a 12 lb fortress and it just sometimes holds me in the lake wind that comes up alot.
PLP Member
NRA member
UFC fan
Capt Sully
#10 Post by Capt Sully » Sun May 11, 2014 1:33 pm
hoosierhick wrote:Sully .Do you have any interference issues ?
No issues at all. I deploy it using about a 5 to 1 scope. The line swings far out and the toon swings in the direction as the wind so the motor is always clear. Retrieving the line comes straight up from the tip of the bracket and clears everything. Like I said, I'm liking this. :thumbsup :thumbsup It also has a safety catch for trailering to support the anchor. :alright
2012 Xcurison X23C
FVC USCG Auxiliary
Vietnam 66 / 67
wijames
#11 Post by wijames » Mon May 12, 2014 4:58 am
Gonefishing wrote:There is a mount. It is a angle mount. Bolts to the floor at the rear. Check with them again. I have seen it on their websit when I was checking on getting one for my toon. But decided the price was not. Worth it. I purchased a shallow water anchor system. A lot cheaper and works great
Which shallow water system did you get? I've tried several and every one has bent or broken. I guess I should have mentioned that I'm wanting something to use in the intercoastal. we regularly get 15-20 kt winds at the beach we go to.
wijames
#12 Post by wijames » Mon May 12, 2014 5:02 am
Capt Sully wrote:Haven't seen that one, heres what I installed. A TRAC 35 made for pontoon mounting. It's electric with a remote control. Iv'e used it only one season so far and it works great and sure beats pulling on a rode. Push a button and it goes up or down. I can stay seated and don't even have to put my beer down. :drink Also it don't matter if you place it on the front or rear on a pontoon, works great.
I just took one of thses off my boat and put it in the garbage! I bought the saltwater version and it still rusted like hell in just one season and the remote quit working after only a couple of months.
wijames
#13 Post by wijames » Mon May 12, 2014 5:03 am
Gonefishing wrote:This is what is use and it works great. Can be purchased from Bass Pro Sho
I've tried these and they just dont do the trick in saltwater, even in 10-15 kt winds.
Mrtoler
#14 Post by Mrtoler » Mon May 12, 2014 6:20 pm
2006 dodge ram quad cab
Crosby Texas
wijames
#15 Post by wijames » Tue May 13, 2014 10:55 am
Mrtoler wrote:Image
Thanks for posting, That would work but was hoping not to have to mount it to my motor tummel or spenf an additional $250.00 for an additional mount. I'm going to the boat show this weekend and hope to see a few installs like this there. They may also have some show specials to bring down the price a little.
