Water hose
smuckie
Water hose
#1 Post by smuckie » Mon Jun 23, 2014 7:47 am
I have a broken fitting on side of my 08 Mercury 115 hp 4 stroke, sorry haven't got my manual yet so I don't know part names but I'll try to post pic, it's a 3/8" rubber hose that goes to a fuel something, maybe cooler? Broke and now water don't come out back of motor, need to know what it's called to get new one
smuckie
Re: Water hose
#2 Post by smuckie » Mon Jun 23, 2014 1:41 pm
Better pic, I hope
tommyz
Re: Water hose
#3 Post by tommyz » Tue Jun 24, 2014 6:02 am
I'm confused by the red lines, but I think the box you're referring to in that pic is the fuel pump assembly. It's uses water pressure to switch hi/lo fuel pumps...somehow. I have seen on mine where the plumbing does also feed the pee-port.
2010 Suntracker 24' Sunchaser
2009 Mercury 90hp EFI/4S
2007 Ford Expedition 4WD
GXPWeasel
Re: Water hose
#4 Post by GXPWeasel » Tue Jun 24, 2014 6:15 am
If you have your engines serial number, and these pictures, (or better yet, a cell phone picture of the part on your engine) and bring it into your local boat dealership / parts place, and show them what you need. This is what they do, and usually know exactly what you're talking about. At least, from my experience.
smuckie
Re: Water hose
#5 Post by smuckie » Tue Jun 24, 2014 8:39 am
Great guys thanks, maybe that'll fix my other issue, it'll only run up to 4900 rpm at 19 mph when other boats like mine run 29 to 31 mph at 6200 rpm
PlaynDoc
Re: Water hose
#6 Post by PlaynDoc » Tue Jun 24, 2014 9:42 am
smuckie wrote:Great guys thanks, maybe that'll fix my other issue, it'll only run up to 4900 rpm at 19 mph when other boats like mine run 29 to 31 mph at 6200 rpm
im not a mechanic, nor prop expert....
but, 4900 at 19mph when you expect more, could be a prop size/pitch issue, more than motor issue.
smuckie
Re: Water hose
#7 Post by smuckie » Tue Jun 24, 2014 10:02 am
That's why I went a head a bought it, I thought the same thing, but it also doesn't rev up in neutral
fergusmj
Re: Water hose
#8 Post by fergusmj » Thu Jun 26, 2014 2:25 pm
go here
https://webapps.brunswick.com/literatur ... eSearch.do
Enter serial number and you can pull up the parts catalog. Good luck.
Ferg's Tritoon Build
