What speed are you getting at WOT and the size of you boat
Bugsbunnyboater
#1 Post by Bugsbunnyboater » Sun Aug 17, 2014 11:51 pm
1995 Sweetwater 18 foot... 10 mph. 25hp Tohatsu
What speeds are you getting.
teecro
Re: What speed are you getting at WOT and the size of you boat
#2 Post by teecro » Mon Aug 18, 2014 5:00 am
2014 Sun Tracker 18 foot with 60 HP 4 Stroke Mercury 2 adults and 30 gallons of gas, cooler and full gear 21 MPH
Soonertoon
#3 Post by Soonertoon » Mon Aug 18, 2014 6:09 am
22 ft G3 Suncatcher w 115 Yamaha 4 stroke 30 m.p.h. wth full fuel tank, Bimini up, 2 adults and 2 teenagers.
Broken Arrow Ok
2014 G3 Suncatcher
115 Yamaha 4 stroke
#4 Post by HandymanHerb » Mon Aug 18, 2014 6:45 am
a 91 grumman 20 footer with a 50 HP 16 mph with four in it, after the rebuild w a 90 HP added I get 21 with four and 20 gallons of fuel
cwag911
#5 Post by cwag911 » Mon Aug 18, 2014 6:52 am
07' Bennington 2275rl w/ Honda 150, 40mph
Carl & Suzi
150 Honda 15x15p Enertia prop
Power assisted steering
Denver, NC Lake Norman
Pleiku, Vietnam 1971
#6 Post by RcgTexas » Mon Aug 18, 2014 7:56 am
1995 21ft Beachcomber converted to tritoon with 135 Honda with 4 adults, bimini up, 5000rpm(SEE below), and 30 gal gas = 31.3 mph/ GPS
That's with a bent prop shaft.(Just discovered that) Seems dealer missed that detail when he sold me the motor. :censored
That's another story.
Matt in Houston
#7 Post by Matt in Houston » Mon Aug 18, 2014 8:14 am
Xcursion X-25C w/ Yamaha 150 4 stroke and Enertia 15 pitch prop. Rear bimini open, 2 adults, one kid, 1/2 tank of fuel, and motor mounted in top hole. 36 MPH GPS at 5600 RPM, 9 hours on motor and outside temps @ ~95 degrees.
2014 Xcursion X-25C Tritoon - XS Pkg - 150 Yamaha 4 Stroke - 15p Enertia
Tankplunkett
#8 Post by Tankplunkett » Mon Aug 18, 2014 8:18 am
1994 Playcraft with 90 horse Johnnson, bimini top up, 2 adults and a little gear, 25 mph.
KPC
#9 Post by KPC » Mon Aug 18, 2014 8:20 am
1985 Mirrocraft, 20' with 1985 Evinrude 25 hp.
GPS shows 18 mph with just me on the boat (in addition to 12 gallons of fuel, battery anchors, gear etc.), 14-15 mph with 3 adults.
KPC
Nashman
#10 Post by Nashman » Mon Aug 18, 2014 9:06 am
2010 Crestliner 2385 Batata Bay 115 Honda 4 Stroke. 26mph with 4 people and a full tank on a good day! ;)
1999 Active Thunder Tantrum 550HP 502CI
2010 Crestliner 2365 Batata Bay w/115 Honda
Tlowry
#11 Post by Tlowry » Mon Aug 18, 2014 9:41 am
2014 Fishn' Barge 22 DLX, 90FS Merc 28mph 1/2 tank, 2 peeps on board.
wed
#12 Post by wed » Mon Aug 18, 2014 10:59 am
2009 Tracker Fishing Barge 21 - Mercury 90 HP 4 stroke, 38MPH GPS @ 5800 RPM with a 13.25 X 17 prop. Lifting strakes help a lot!
2007 GMC Sierra
willy13
#13 Post by willy13 » Mon Aug 18, 2014 11:06 am
1992 24 ft Suntracker with a 2013 Yamaha 115HP = 25 mph
#14 Post by curtiscapk » Mon Aug 18, 2014 11:15 am
see my sig!
rob28
#15 Post by rob28 » Mon Aug 18, 2014 11:34 am
2013 Sylvan Mirage 8520 Cruise - 20 footer with a Mercury 50 Bigfoot.
GPS'd at 18.5mph with 2 people, 2 batteries and a full tank of fuel (130L)
