electrical question
electrical question
Hey guys. Ran into a bit of an issue when trying to wire up my New fishfinder today. Turns out the old fishfinder was connected to the fuse panel with a piggyback tab connector. It had a much larger gauge cable (relatively speaking) that is connected to the other circuits. Nothing can be simple plug and play. Anywho, so you guys know where I can pick one up? Auto parts store? I've never seen these before. What's the point of them?
2014 Sweetwater 2086SW
90 Hp Yamaha 4-stroke
Re: electrical question
16 ga wire is sufficient for a FF.
Is this the type of connector you're referring to? If so, yes any auto parts store as well as the Home Depot or Loweswill have them.
1989 28' Tracker Party Hut
115 hp 4 stroke Yamaha
Sacramento, Ca
Sacramento, Ca
Do you have another spare fuse location that you can add your fishfinder to?
Very inexpensive to add another fuse holder for future use if you don't.
Mercury 90 4 stroke
Mercury 90 4 stroke
I do not recall seeing any free circuits. Although, I remember seeing a black and red wire with butt connectors on them with nothing attached. There is an aux switch on the dash that doesn't do anything. Wonder if that is it?
In any case, I couldn't find the connector I was looking for, but I found this instead. I think I can make this work!
- Boat_WireConnector.jpg (59.24 KiB) Viewed 1192 times
The auxiliary switch may just be it! invest in a twelve vote tester if you don't have one, they are invaluable with boat voltage (12).
