Fuel Guage Add On
sharky300
Fuel Guage Add On
#1 Post by sharky300 » Mon Mar 30, 2015 2:47 pm
Good day all!!!
I apologize if this has been covered... I tried to search it but did not see anything that answered the question.
I bough a 1988 24' Grumman Fun Ship last year. It runs great and we had an awesome summer on it... As to be expected on a vessel of this age, it needs some TLC and updating... I am going to go at it a little at a time, and one of the projects I wanted to tackle this year was repairing/adding fuel gauge on the dash. I will start by saying that the dash, and probably the fuel tank, appear to have been replaced at some point in time. None of the gauges on the dash work. The fuel tank is plastic, 20 gallon, and has a gauge built into the top of the tank- next to the filler hole. My question... Is there an aftermarket gauge I can add to the system??? I guess while I am at it... what about all of the gauges... Fuel/Trim/Speed/ etc... Is there a kit for something like this?
Any help is greatly appreciated!!!
Jason
HarryO
Re: Fuel Guage Add On
#2 Post by HarryO » Mon Mar 30, 2015 3:40 pm
I would try searching Ebay for a fuel level sensing kit. You should find something that will work for between $20 to $30.
Crusing on the Delaware River and fishing the Delaware Bay
2006 King Viper 2160
Suzuki 225DF
2001 Weeres Sportsman 20
Evinrude 50hp 2 stroke
ToonGuy
#3 Post by ToonGuy » Tue Mar 31, 2015 5:19 am
There is no "kit" because some gauges are motor-specific. IF your motor has a trim sending unit, you need to buy a gauge that matches your make of motor. As mentioned, ebay is good source for fuel sending units. You will need to match the fuel gauge to your sender ohms, however 99% are compatible. A volt gauge is a must have, and they are universal. I would also suggest a tach, most will be compatible. Don't waste your money on an old school speedo, they are incredibly inaccurate. Get a fish finder with GPS built in, or use a GPS app on a smart phone if you really need to know your true speed. Good luck.
sharky300
#4 Post by sharky300 » Fri Apr 10, 2015 10:01 am
Great info! Thanks for help!!!
I have started searching the wide world of Ebay- and will get these in the works this week!!!!
Do you all suggest using Pre-made wiring harness, or just wire as you go??
I have just ordered a book on marine/12V wiring systems. I am sure it will have its opinion in that area... just curious what y'all do.
Thanks again!!
Jason
#5 Post by curtiscapk » Fri Apr 10, 2015 10:38 am
these may help...
sharky300
#6 Post by sharky300 » Fri Apr 10, 2015 2:26 pm
Awesome-Thanks!!!
That will help out a TON!!!
Jason
