Battery switch
Will
Battery switch
#1 Post by Will » Tue Apr 21, 2015 11:15 am
How important is a battery switch can I live without it or is it worth the couple of hundred for it
2010 Berkshire 200 CL with a 50hp bf 4 stroke Merc
2006 Sea Ray 185 Sport
"You can go through life half-heartedly and still succeed"
Seon
Re: Battery switch
#2 Post by Seon » Tue Apr 21, 2015 11:30 am
If you're referring to this type of switch then I'd say yes. BTW it only cost about $50 and easy to install.
1989 28' Tracker Party Hut
115 hp 4 stroke Yamaha
Sacramento, Ca
Will
Re: Battery switch
#3 Post by Will » Tue Apr 21, 2015 11:36 am
Interesting Seon they want $223 installed at the dealer
Re: Battery switch
#4 Post by curtiscapk » Tue Apr 21, 2015 11:42 am
I have lived without one for 7 years, and both my batteries are still alive. Saying that it is an easy install. :)
Seon
Re: Battery switch
#5 Post by Seon » Tue Apr 21, 2015 1:49 pm
Will wrote:Interesting Seon they want $223 installed at the dealer
Not much to installing them.
Sacramento, Ca
Capt Sully
Re: Battery switch
#6 Post by Capt Sully » Tue Apr 21, 2015 2:31 pm
Heres another one
battery switch.jpg (92.58 KiB) Viewed 3129 times
2012 Xcurison X23C
Yamaha 90 hp 4 stroke
Maritime mobile KD4LZL
Lake Allatoona, NW Ga.
FVC USCG Auxiliary
Vietnam 66 / 67
catesmw@att.net
Re: Battery switch
#7 Post by catesmw@att.net » Tue Apr 21, 2015 2:42 pm
I installed this on my Chaparral Cuddy, saved me from being stranded or needing a jump too many times to count. Simple to install for sure.
teecro
Re: Battery switch
#8 Post by teecro » Tue Apr 21, 2015 3:15 pm
Well does that price also include the 2nd battery and perhaps a battery box, what about the extra battery cables that will be needed, what about the labor to install the system?
A question that comes to mind is why do you think that you need one? Do you plan on spending a lot of time running equipment that draws current while the motor is not running?
Not that 2nd battery is not a good idea as it is but do you really need one? I spent least 12 years with my father running small boats across a large lake day in and day out we never had but one battery.
ron nh
Re: Battery switch
#9 Post by ron nh » Tue Apr 21, 2015 3:24 pm
if I buy a 2nd battery should one be just to start and the other a deep cycle for everything else? I kind of like the sounds of the loons and other stuff so I haven't used the radio much in the past, but might be different now on a pontoon.
Re: Battery switch
#10 Post by Bamaman » Tue Apr 21, 2015 3:29 pm
If you had a boat that got way out in the ocean or Gulf, you might need 2 batteries. Pontoons are not used in that manner.
Or, if you have a huge power sucking amplifier with your sound system (with subwoofer) and you sit for hours floating around listening to tunes, you might need a 2nd battery--or 3rd battery.
Or if you have a trolling motor, you might need a 2nd battery.
I've had boats since 1974 with one battery, and I've never been stranded.
Re: Battery switch
#11 Post by Bamaman » Tue Apr 21, 2015 3:29 pm
Seon
Re: Battery switch
#12 Post by Seon » Tue Apr 21, 2015 5:16 pm
All good points :thumbsup
Sacramento, Ca
