Adding lift strakes
Crab Island Cruiser
Adding lift strakes
#1 Post by Crab Island Cruiser » Sat Jun 13, 2015 2:20 pm
I finally found a local fab shop that can/will install lift strakes on my toon.
He will only be adding one strake to each toon. Should I go inside or outside?
Also, he asked how long I would like the strakes. Anyone have an idea what length I should use?
My toon is a 22 footer. I saw a G3 today with strakes and the strakes started approx 1 foot from the
nose cone weld line where it meets the rest of the log.
Thanks in advance!!
07 22' Sun Chaser
Yami F115 power
low and slow
BoatCop
Re: Adding lift strakes
#2 Post by BoatCop » Sat Jun 13, 2015 6:16 pm
Check with your boat's manufacturer before doing this. I planned to do it on my Sun Tracker but they told me that any unauthorized welding done on the toons would invalidate any warranty on them.
As far as how long and exact placement, try and find a boat that's the same make and model, but with factory strakes and measure it out.
Alan
2016 Chevy Tahoe
2009 GMC Sierra
2001 Jeep TJ Wrangler
1999 Southwind 34L MH
2 little Basset Hounds
#3 Post by Bamaman » Sat Jun 13, 2015 6:45 pm
What brand, model and length boat are you wanting to modify? How many toons and what size engine are you running now?
Manufacturers have spent substantial engineering and test time on the water designing their lifting strakes. They have specific lengths, angles, material gauge, placement front and back, placement from the bottom keel. It's just a complicated subject. On late model boats, manufacturers will often furnish the materials and ship fabricated strakes to a dealer with another boat delivery.
Let us know the above and good suggestions will follow.
MH Hawker
#4 Post by MH Hawker » Sat Jun 13, 2015 8:05 pm
I would suggest you not add them, i haven't seen it work out yet most end up leaking
Crab Island Cruiser
#5 Post by Crab Island Cruiser » Sun Jun 14, 2015 4:49 am
Bamaman wrote:What brand, model and length boat are you wanting to modify? How many toons and what size engine are you running now?
I don't think I have any warranty left on my boat. To the best of my knowledge, I'm the 3rd owner and the PO didn't mention anything about a warranty.
Details, I guess I should add a signature at some point. lol
22' Sun Chaser, Yami F115 TLR 4 stroke, 2-25"D toons.
I contacted the local dealer about adding a center toon. They contacted the manufacturer and were told my boat didn't come with a center toon so they would not sell me one.
07 22' Sun Chaser
Yami F115 power
low and slow
ron nh
#6 Post by ron nh » Sun Jun 14, 2015 5:06 am
with motor/boat combo you should benefit from strakes in theory. it's such a fine process, like has been said, get the exact strake and put in the exact location. good luck.
farmer_dre
#7 Post by farmer_dre » Sun Jun 14, 2015 5:19 am
Also check too..
if those d shape toons are filled with foam ..... I was looking at a sunchaser before i bought my Manitou, and the one i was looking at had foam filled toons. It might not be a problem. i could only magin it would be melting on the inside as you weld on the outside!
good luck, let us know how you make out . im interested to hear.
2009 GMC Sierra 2500 Duramax
2015 Manitou Aurora 23 RF W/175 suzuki
ron nh
#8 Post by ron nh » Sun Jun 14, 2015 5:33 am
I believe your confusing sun catcher for sun chaser. I could be wrong but I don't think sun chaser used foam.
farmer_dre
#9 Post by farmer_dre » Sun Jun 14, 2015 9:28 am
ron nh wrote:I believe your confusing sun catcher for sun chaser. I could be wrong but I don't think sun chaser used foam.
your right my bad. i was thinking Sun Catcher.
Crab Island Cruiser
#10 Post by Crab Island Cruiser » Sun Jun 14, 2015 5:23 pm
I don't think I have foam in the tubes.
I looked at a sun catcher today at bass pro. It was a tritoon with strakes.
Then strakes started at the weld mark of the nose cone/tube and stopped a couple feet short of the end of the tube.
I thought that was strange since the back half of the boat will be in the water on plane, but hell, I'm no boat engineer
or hydrodynamics engineer. lol
I'm interested in all the feedback I can get on the strake subject before I pull the trigger.
07 22' Sun Chaser
Yami F115 power
low and slow
#11 Post by RcgTexas » Sun Jun 14, 2015 6:11 pm
Check out this website. These guys build all kinds of pontoons and pontoon boats.
http://www.custompontoonboatkitsetc.com/id5.html
One picture I saw was lifting strakes on a center log with a motor mount. The strakes appear to go from aft of the nose cone to the stern.
Its one of the reasons I had my center log made locally and with a flat bottom.
Crab Island Cruiser
#12 Post by Crab Island Cruiser » Mon Jun 15, 2015 3:21 am
RcgTexas wrote:Check out this website. These guys build all kinds of pontoons and pontoon boats.
I bet that cost you a pretty penny.
I contacted Avalon about getting a pony tube. They said no since I don't own an Avalon.
I guess I need to try Bennington.
07 22' Sun Chaser
Yami F115 power
low and slow
ToonGuy
#13 Post by ToonGuy » Mon Jun 15, 2015 5:41 am
Where are you located?
#14 Post by RcgTexas » Mon Jun 15, 2015 8:13 am
Actually the prices weren't that different. About $2300 with the strakes but the shipping from Indiana or Ohio, I forget which, was the deal breaker. With my new center log I have never had a boat that got on plane faster.
Waterlogged
#15 Post by Waterlogged » Mon Jun 15, 2015 11:47 am
Don't know why, but my strakes end 30" from the rear of toons. Sun Tracker PB 22.
2008 Mercury 115 4 stroke
