Add-on double bimini (after market?)
CajunCoach23
Hi.
We have a Coach 23c with the single bimini and would like to "add" the additional front bimini. The dealer only sells the double as a complete unit and would not give any credit for accepting the single bimini.
Question to the group - do you have any knowledge of attaching a single front bimini to an existing rear single bimini?
2016 Coach 23C
2016 Honda 150
2016 Honda 150
Re: Add-on double bimini (after market?)
To be honest there is no real need to connect the 2nd bimini to the first. I'm very happy with the 2nd top that I got for our toon from www.topmastermarine.com I simply adjusted the angle so that one top overlaps the other by a little bit. We can open the 2nd top in just moments or close it as weather/sun dictate....
- fwd rad.jpg (91.78 KiB) Viewed 4279 times
Gonefishing
Very easily done. I did it and had no problem.
Bob Jacksonville, Nc
2013 Excursion X23 RFC
2013 115 Yamaha
Pulled with a Ford King Ranch
2013 115 Yamaha
CajunCoach23
Gonefishing wrote:Very easily done. I did it and had no problem.
Thanks for reply but which top are you referring to...the previous poster?
Thanks!
2016 Coach 23C
2016 Honda 150
2016 Honda 150
Try searching past threads on the subject such as this one viewtopic.php?f=2&t=20841&hilit=biminiCajunCoach23 wrote: Thanks for reply but which top are you referring to...the previous poster?
Having the two tops connected will most likely require a visit to a local shop to alter them so as to zip together.
Keep in mind how you intend to use; if you insist on having the 2 tops connected you may not be able to use one or the other as conditions my dictate. As I have 2 separate tops I can open or close which ever one I so choose.
Another factor is cost and what your willing to spend, a 2nd top can be added for 4 to 5 hundred while a full double can be well double in price....
Here is the thread where i did my install for a second top. It has worked out extremely well.
viewtopic.php?f=2&t=21540&p=178614&hilit=bimini#p178614
Tim
Tim
CajunCoach23
WOW...very nice looking and also some very handy work! I will definitely refer to your thread if we decide to go double!Cowracer wrote:Here is the thread where i did my install for a second top. It has worked out extremely well.
Tim
Thanks!
Mitch
2016 Coach 23C
2016 Honda 150
2016 Honda 150
