Gauges not working
Osubauer
Gauges not working
#1 Post by Osubauer » Sun Aug 07, 2016 5:07 pm
The gauges which read engine info (tachometer, hour meter, trim) are not working. The tachometer and trim gauges respond to the initialization when key is turned on but nothing after. I assume it's a signal issue and not a fuse since they do the initialization. They are Faria analog gauges connected to a Mercury Verado 150. Any ideas where to start troubleshooting?
2006 Harris Super Sunliner 240, 2006 Mercury Verado 150
"I'm back to living Floridays, blue skies and ultraviolet rays..."
-Jimmy Buffett
rob28
Re: Gauges not working
#2 Post by rob28 » Sun Aug 07, 2016 5:42 pm
If they're all analogue gauges, and this fault is common across all the gauges it may be a bad ground.
Not sure how they are connected to though. Did you get a wiring diagram with the boat or motor?
Drago
#3 Post by Drago » Mon Aug 08, 2016 2:20 pm
definitely crawl under the helm and wiggle some wires. Especially the ground wires coming from gauge cluster.
Kenneth & Joy
Lake Conroe, Texas
2007 Bennington 2577RFSi
2006 Yamaha F225
Solas 14.25x17SS prop
Best ever top speed 69.2KPH
#4 Post by curtiscapk » Tue Aug 09, 2016 6:19 am
try this.
