1996 Landau BT-20 rebuild
Bt20bill
#1 Post by Bt20bill » Thu Mar 05, 2020 3:23 pm
Refurbishing my 1996 Landau Bt-20, Cleaned pontoons, new deck and added vinyl flooring. I will try to post pictures as I go on this rebuild.I built my roller with form tube that I saw on this forum cant find the original post to give credit so if anyone knows who originally built and posted it give some credit. I'll keep looking for it.
bt20bill
95 Landau Bandit 20
Florida
Re: 1996 Landau BT-20 rebuild
#2 Post by curtiscapk » Thu Mar 05, 2020 3:26 pm
Nice!!!!! more pics the better! I have tons of pics on my rebuild post in my sig!
#3 Post by bansil » Fri Mar 06, 2020 5:14 am
:smoke
You should be ready for summer :nana
Moar pics better
Bt20bill
#4 Post by Bt20bill » Fri Mar 06, 2020 9:14 am
Just finished trimming vinyl everything going well up to now.Trying to decide if I should cut holes or put trim on first. Looking to see if my control cables will fish through holes because there is not much space on Landau between pontoon logs and deck since I am rearranging the furniture and moving console back 18" from original I may need to get creative.
bt20bill
95 Landau Bandit 20
Florida
TWB
#5 Post by TWB » Fri Mar 06, 2020 3:54 pm
Getting ready to start on my 24' Landau and also expecting to re-run the cables. I'm going to watch your thread closely to see how it goes.
Post pics. Good Luck!
-Paul
Paul & Michele
2003 Mercury 75hp
Bt20bill
#6 Post by Bt20bill » Sun Mar 08, 2020 10:36 am
After looking at the measurements on the original hole for the shift/speed control cables the hole was cut 10 1/2" inches from the edge. I was going to set mine up the same way as original but decided against it, I was concerned that the original way the cables were ran would make it difficult if I ever had to replace them so I will come up through deck and have cut 2" hole 4" from edge to center of hole try to come up with something to cover them. The cables were easy to pass through deck without any excessive bending.
bt20bill
95 Landau Bandit 20
Florida
TWB
#7 Post by TWB » Mon Mar 09, 2020 6:30 am
A couple of years ago I had to replace the steering cable. Found out what a booger it was, especially found the importance of the correct length. It's a thick, mostly unforgiving cable. If you're using the existing one, I wonder if you'll see any issues running your steering cable if it's an 18" shorter run?
:donno
Paul & Michele
2003 Mercury 75hp
Bt20bill
#8 Post by Bt20bill » Tue Mar 10, 2020 1:45 pm
I am concerned about the cable length also, thats why I decided to make it a little closer to deck edge so it would be easier to change if needed and I am going to move the control a little closer to console. I am thinking I may be able to get the control less than a foot shorter. Hoping I don't have to buy new cables.
bt20bill
95 Landau Bandit 20
Florida
Bt20bill
#9 Post by Bt20bill » Fri Mar 13, 2020 5:58 am
My 20ft pontoon boat does not have a front deck. I have been thinking about removing my 2 side gates which should give about 27" for a front deck. The problem I see with this is the loss of side gates and still not sure if 27" would be enough to allow for 2 folding/swivel fishing chairs on front deck. Does anyone have a front deck this size with fishing chairs and what are the pros/cons of putting them on this size deck.
bt20bill
95 Landau Bandit 20
Florida
Bt20bill
#10 Post by Bt20bill » Fri Mar 13, 2020 3:22 pm
Well, live and learn I was bolting my rails to deck today on my Landau BT20 and found out that you cannot reach the rail bolts to add washer and nuts after putting deck trim on which is a bear if you are reusing the C channel and 84mil vinyl. So I am removing the deck trim so that I can reach the bolts to add washers and nuts to bottom of rail bolts. The problem is after adding the C channel deck trim there is only about 1/2 inch gap between the bottom of the trim and the edge of pontoon log which is not enough room for fingers or wrenches.
bt20bill
95 Landau Bandit 20
Florida
Bt20bill
#11 Post by Bt20bill » Mon Mar 16, 2020 4:18 pm
Ordered seats today be here on Thursday, I guess I will glove up and wear windbreaker and mask to store them for a few days before unboxing them maybe spray the boxes with Lysol.Darn virus has everything upside down now.
bt20bill
95 Landau Bandit 20
Florida
TWB
#12 Post by TWB » Tue Mar 17, 2020 5:12 am
I, too, noticed when I removed my rail that it was the only way to reach those nuts. The Landau seems to sit right on top of the logs. Makes it a bit of a contortionist move to reach things. But - I do like the look of the deck sitting down close on the logs with no big space.
I got lucky(ish) and checked my measurements moments before ordering the flooring kit. My 24' is actually 24'6"! Have to order the 28' kit - another $150. B-O-A-T!
-Paul
Paul & Michele
2003 Mercury 75hp
Bt20bill
#13 Post by Bt20bill » Thu Mar 26, 2020 6:12 am
Yes, I also like the look of it with closed space between logs and deck.
bt20bill
95 Landau Bandit 20
Florida
Bt20bill
#14 Post by Bt20bill » Thu Mar 26, 2020 6:42 am
Starting to add rails on boat.
bt20bill
95 Landau Bandit 20
Florida
Bt20bill
#15 Post by Bt20bill » Thu Mar 26, 2020 6:49 am
Deckmate furniture is unpacked and starting to put them together. Some notes about the slots in bases for the backrests. The slots were routed about 3/4" wide and the fender washers supplied are about 1" wide this causes the washer to slip through the slots and does not hold seat backs well. I purchased 1.5" fender washers to fix this and it worked to hold them more secure. You can see the slots in this picture.
bt20bill
95 Landau Bandit 20
Florida
