Sprk Plug Wire
Woody
Re: Sprk Plug Wire
#16 Post by Woody » Wed Sep 05, 2012 11:36 am
On my PWC's, the boots "screw" into the wires. I've never paid any attention to my outboard wires.
2019 Veranda 22 RFL 250SHO
Ron Burgundy
Re: Sprk Plug Wire
#17 Post by Ron Burgundy » Wed Sep 05, 2012 11:59 am
I just now shoved it in, and it works.
GregF
Re: Sprk Plug Wire
#18 Post by GregF » Wed Sep 05, 2012 12:54 pm
Good deal.
1974 Harris
70 HP 4 stroke EFI Yamaha
ROBBSRACINGENGINES
Re: Sprk Plug Wire
#19 Post by ROBBSRACINGENGINES » Wed Sep 05, 2012 1:46 pm
Most plug wires DONT come out of the coil any more. Most plug boots thread into the plug wire. Look up inside the plug boot and see if it looks like a screw up in there. It most likely does. If so snip just the split part off the end of your wire, slip it into the boot and twist the boot as if you were tightening a screw. Should be good as new. If the boot is not threaded, which I would be VERY surprised, then go to a motorcycle shop, buy one that is and do as I described above.
GregF
Re: Sprk Plug Wire
#20 Post by GregF » Wed Sep 05, 2012 6:08 pm
Old guy learns something. The last I screwed with marine plug wires they were solid "good" stainless wire (316) with crimped on ends.
1974 Harris
Re: Sprk Plug Wire
#21 Post by curtiscapk » Wed Sep 05, 2012 8:20 pm
here is my jerry rig from 2 years ago... It was a little different the end burnt (shorted) off and I used a wire terminal to finish the day.
