Manitou Xplode - Center tube access port
GaCarolinaTn
#1 Post by GaCarolinaTn » Fri Oct 05, 2012 3:32 pm
My 2012 Xplode has a round white access panel just forward of the engine in the center tube.
Does anyone know why this is part of the design? What purpose does it serve?
Thanks!
2007 KTM EXC 525
2007 Yamaha TTR 90 (Son's Bike)
2008 Yamaha TTR 50 (Daughter's Bike)
2012 Manitou Xplode w/ Suzuki 250SS
Mrtoler
Re: Manitou Xplode - Center tube access port
#2 Post by Mrtoler » Fri Oct 05, 2012 4:28 pm
Access to the motor mounting bolts....maybe
2006 dodge ram quad cab
Crosby Texas
BoatCop
#3 Post by BoatCop » Fri Oct 05, 2012 6:12 pm
The Crest Tri-toons have a fuel cell in the center log. Except in our model the tank is accessible through a panel in the floor of the deck.
Alan
2016 Chevy Tahoe
2009 GMC Sierra
2001 Jeep TJ Wrangler
1999 Southwind 34L MH
2 little Basset Hounds
#4 Post by Bamaman » Fri Oct 05, 2012 7:54 pm
You'll usually find the fuel line junctions under that plate. Wiring/conduit also may be going through that area.
PlaynDoc
#5 Post by PlaynDoc » Fri Oct 05, 2012 9:17 pm
It's to hide your marijuana, as you're travelling from jamacia to miami!
#6 Post by Bryden24shp » Fri Oct 05, 2012 10:43 pm
Mrtoler is exactly right!, When we designed the new transom in 2009, we encapsulated the transom and needed an access hole to get to the nuts behind the transom for the motor mounting bolts.
Good Job!
GaCarolinaTn
#7 Post by GaCarolinaTn » Sat Oct 06, 2012 10:38 am
Thanks guys!
2007 KTM EXC 525
Mrtoler
#8 Post by Mrtoler » Sat Oct 06, 2012 11:20 am
Yesssss!!!!! I can't believe it I finally got one right....waaaahooo :nana :nana
Crosby Texas
#9 Post by Bryden24shp » Tue Oct 09, 2012 2:07 pm
Here is a picture of the prototype transom, that we built. Should be the same as yours. Took me awhile to find it, since I have split paths between Manitou and Premier.
Bryan H 001.jpg (46.47 KiB) Viewed 2111 times
slingshot
#10 Post by slingshot » Tue Oct 09, 2012 4:55 pm
Bryden24shp wrote:Mrtoler is exactly right!, When we designed the new transom in 2009, we encapsulated the transom and needed an access hole to get to the nuts behind the transom for the motor mounting bolts.
Good Job!
OK.....Right.....but we can still use it to hide our marijuana, right?
2007, 2570 Crest LE II
Yamaha F150
#11 Post by Bryden24shp » Tue Oct 09, 2012 5:38 pm
[quote="slingshotOK.....Right.....but we can still use it to hide are marijuana, right?[/quote]
There enough room in there for that, your bong, a 12 pack of one hitters and a 30 pack of Bud Light, on ice!
When's the party? Woo Hoo!!!
