Ski Bar Paint
fod59
Ski Bar Paint
#1 Post by fod59 » Sun Nov 18, 2012 10:18 pm
My neighbor is making a ski bar for me,what would the best paint be for it.Have anyone used chrome paint
2007 Odyssey 322
115 Johnson 4 Stroke
Carmi Il
MH Hawker
Re: Ski Bar Paint
#2 Post by MH Hawker » Mon Nov 19, 2012 3:05 am
I have use the aluminum paint with clear coat over top with decent results.
Re: Ski Bar Paint
#3 Post by Bamaman » Mon Nov 19, 2012 7:00 am
See if you can find someone to powercoat it. They have some heavy metallic and silver colors.
A more expensive option would be to find a chrome outfit--if it's really, really nice.
GXPWeasel
Re: Ski Bar Paint
#4 Post by GXPWeasel » Mon Nov 19, 2012 7:06 am
I agree, powdercoat if you can. If not, I did 3 coats of primer, sanded between each one, then 3 coats of color, sanding between each coat, and topped off with 2 coats of clear. Mine still looks like new, after 2 years in the elements.
My ski tow bar is made from steel tubing though, not aluminum.
"Nauti Weasel"
2005 Beachcomber Islander 26
ronb
Re: Ski Bar Paint
#5 Post by ronb » Mon Nov 19, 2012 8:30 am
When I built mine, I ended up just painting it with aluminum colored paint
Building a Ski/Tube tow bar
But now I am thinking I should pull it back off and have it powder coated. The paint worked just fine, no complaints. The only problem I had (my fault) was the first time we had the pontoon out after installation of the tube/ski tow bar, my tube was sitting on the sun deck and it flew off (tied to the boat still) but the rope drug across the relatively fresh paint and scuffed the snot out of it. The scuffs are not that obvious but if you are looking for them, you can see them.
-ron
Re: Ski Bar Paint
#6 Post by badmoonrising » Mon Nov 19, 2012 11:13 am
I concur on powder coating.
cwag911
Re: Ski Bar Paint
#7 Post by cwag911 » Wed Nov 21, 2012 11:29 am
I agree on powder coating, it'll last forever and it's rock solid.
Carl & Suzi
150 Honda 15x15p Enertia prop
Power assisted steering
Denver, NC Lake Norman
Pleiku, Vietnam 1971
