Where Would You Mount the Humminbird?
- Mosnowman
So I have a new Humminbird 597- 5 inch screen and would love some advice/opinions from you experienced guys on where to mount it? I have included a link to the pictures of the helm. I have a ram mount that I will be using so I can play with angles to make it work. I was thinking either on the flat part of the helm on the left side above the stereo? Or possibly to the left of that above the stereo mounted on the angle of the Helm? Thanks for any input!
http://s1118.beta.photobucket.com/user/ ... d.jpg.html
BUSY LIVING...
Columbia Mo BZLIVN
Columbia Mo BZLIVN
Re: Where Would You Mount the Humminbird?
I picked up a Ram mount for mine. Anywhere on the dash blocked the gauges and made manipulating the buttons on the sonar really awkward.
2011 Sweetwater 206F Sunrise
2011 60 HP Evinrude Etec
Humminbird 798SiHd
Boating on Moose, Pigeon, Lac St. Anne and Sask Landing
Humminbird 798SiHd
Mine is in the same place--for the same reasons.bobalong wrote:I picked up a Ram mount for mine. Anywhere on the dash blocked the gauges and made manipulating the buttons on the sonar really awkward.
Same spot here for the same reasons.
150 yamaha 4 stroke
2012 tundra tow rig
150 yamaha 4 stroke
2012 tundra tow rig
Well here is where I have mine.
- P1010012 (2).JPG (648.73 KiB) Viewed 2952 times
I'd put it on the right hand side maybe in front of the switches or even above the throttle if space permits. What bugs me about putting it on the left is it makes it vulnerable to others hitting it (or even yourself) from just going by the console.
2012 18' Sweetwater 1880
2012 Yamaha T50
2012 Yamaha T50
I put mine here on the dash
- new consol 12.JPG (124.15 KiB) Viewed 2760 times
That was where I was going to suggest.ubugray wrote:I'd put it on the right hand side maybe in front of the switches or even above the throttle if space permits. What bugs me about putting it on the left is it makes it vulnerable to others hitting it (or even yourself) from just going by the console.
I wanted a more custom look, here's mine
2006 dodge ram quad cab
Crosby Texas
Crosby Texas
Right behind his tailfeathers
2011 Evinrude E-Tec 115 HO
Full Enclosure
Full Enclosure
I have a larger Humminbird finder and I was reluctant to drill hols in the console for any kind of mount. I built an aluminum bracket that bolts onto the right side of the fiberglass console using the horn and the horns mounting features, no drilling required in the boat. The bracket supports the finder and its factory mount and looks really good. I will try to get pics ASAP.
Not sure how your helm is set up but this is mine...
Kenneth & Joy
Lake Conroe, Texas
2007 Bennington 2577RFSi
2006 Yamaha F225
Solas 14.25x17SS prop
Best ever top speed 69.2KPH
Lake Conroe, Texas
2006 Yamaha F225
- Texoma Toon
Mine is mounted in the dash but if I ever add and external one it will be on a gimbal mount so I can swing it around to see it if I am fishing in the front of the toon.
2007 G3 LX 22 Fish & Cruise
90 Hp Yammy
Dual Axle Trailer
90 Hp Yammy
Dual Axle Trailer
Very nice, wish I would have had the room to do that.Mrtoler wrote:I wanted a more custom look, here's mine
Humminbird 798SiHd
Humminbird 798SiHd
- Silver Eagle
I put mine in a cup holder on the right side.Which means I can remove mine when not in use.
