Poor Neighbor
omar174
Poor Neighbor
#1 Post by omar174 » Tue May 28, 2013 9:32 am
Bad start to the season.
Copy of sinking2.JPG (96.17 KiB) Viewed 4300 times
Copy of sinking1.JPG (99.83 KiB) Viewed 4299 times
2004 Hurricane GS211
Yamaha 150 OX66
steveiam
Re: Poor Neighbor
#2 Post by steveiam » Tue May 28, 2013 9:40 am
Wow-any idea how that happened?
omar174
Re: Poor Neighbor
#3 Post by omar174 » Tue May 28, 2013 9:45 am
steveiam wrote:Wow-any idea how that happened?
It was REALLY windy in Ocean City, MD last Friday night. The tie down hook that is welded to the pontoon got yanked off and left a big hole in the tube.
Yamaha 150 OX66
Re: Poor Neighbor
#4 Post by HandymanHerb » Tue May 28, 2013 10:26 am
That's why you use that hook for lifting only, it doesn't like side forces
Re: Poor Neighbor
#5 Post by badmoonrising » Tue May 28, 2013 10:51 am
Yep...weather around here in spring has gotten progressively worse every year. See what happened to my boat despite 5 cleats with 1/2 inch lines :x :x :x :x :x
I won't miss slipping here at all. :scared
Check out Tow Boat US's Facebook page for the upper Chesapeake. :scared
Guy made a ton of $$$ for multiple ungroundings, boats broke loose from slips, and 2 boat fires. One guy in a cruiser ran over a jetty and sunk his vessel.
evinrude2stroke
Re: Poor Neighbor
#6 Post by evinrude2stroke » Tue May 28, 2013 6:47 pm
Interesting, I wonder if his insurance will cover it based since it wasn't tied to cleats :paranoid
Dave
cleatus
Re: Poor Neighbor
#7 Post by cleatus » Wed May 29, 2013 6:03 pm
how about pulling tubes and skiers? I've read many opinions about that, my dealer said it was ok to use the eyes for pulling tubes, i use a bridle hooked on both.
How about towing another boat, will they hold up to that stress?
shiat, i'm getting all mixed up.
here, pull my finger
2011 Godfrey Sweetwater
Yamaha F70
omar174
Re: Poor Neighbor
#8 Post by omar174 » Wed May 29, 2013 6:55 pm
Not sure about that particular Starcraft, but my 2006 didn't have cleats. Just the eyelets welded to the tube. No other place to tie off.
Yamaha 150 OX66
Re: Poor Neighbor
#9 Post by HandymanHerb » Wed May 29, 2013 7:33 pm
They are made to pull straight up, people have got away with using them for tow rope use, some have had cracks form, no way would I pull and boat with them, if you don't have cleats in the back, put them on, or at least some good strong eyelets.
Might not cause a problem, but why take a chance
Re: Poor Neighbor
#10 Post by badmoonrising » Wed May 29, 2013 8:23 pm
Yep. I was specifically told by Tracker ( I e-mailed the factory reps) NOT to use the log eyelets for tying to a slip. The port and stern cleat welded onto the log has a HUGE backer inside the log, that's fine...eyelets have no side to side strength. A lot of 'toons on the bay have the log eyelets bent or broken off due to our nasty weather.
tuned
Re: Poor Neighbor
#11 Post by tuned » Thu May 30, 2013 10:33 am
+1 on the don't use the eyelets concept.
I always use dock rings with four bolts each thru the rub rail and through the deck wood, with extra large fender washers and nylock nuts underneath. Never a problem.
evinrude2stroke
Re: Poor Neighbor
#12 Post by evinrude2stroke » Thu May 30, 2013 10:39 am
omar174 wrote:Not sure about that particular Starcraft, but my 2006 didn't have cleats. Just the eyelets welded to the tube. No other place to tie off.
Mine didn't come with cleats either. I used the eyelets for a long time but after reading about them cracking I installed cleats just to be on the safe side.
Dave
Drago
Re: Poor Neighbor
#13 Post by Drago » Tue Jun 04, 2013 10:31 am
So this is the wrong way??
So what do folks tie the anchor rope too?
Kenneth & Joy
Lake Conroe, Texas
2007 Bennington 2577RFSi
2006 Yamaha F225
Solas 14.25x17SS prop
Best ever top speed 69.2KPH
redbeard
Re: Poor Neighbor
#14 Post by redbeard » Tue Jun 04, 2013 10:44 am
That's what they say.
Re: Poor Neighbor
#15 Post by curtiscapk » Tue Jun 04, 2013 11:47 am
Drago wrote:So this is the wrong way??
I had an eyelet right behind my nav light or a cleat a little further back on the side, I tied mine too. What is that behind your bumber looks like a cleat to me?
