Bought a use pontoon from a guy who has it bow mounted with a Minn Kota power drive v-2 trolling motor. He has never used it, as a second owner! When you push down on the "deploy assist lever", should I just push it forward to get it in the water? It doesn't "go down" easily.
Just push it straight forward until it drops vertical? It seems to hang up on the curved resting place. Not sure I described the problem very well. Thanks for any help offered.
deploying and retracting trolling motor
- killerkernrich
Re: deploying and retracting trolling motor
I have that same setup on my toon you just adjust the locking ring to the depth you want the motor, when not in use just pull it straight up an let the lever lock it up.
I will look for a picture of mine.
PLP Member
NRA member
UFC fan
PLP Member
NRA member
UFC fan
- killerkernrich
found this pic of it in the up when not in use.
might be a bit large pic ...sorry
- DSCF3402.JPG (1.89 MiB) Viewed 1214 times
PLP Member
NRA member
UFC fan
PLP Member
NRA member
UFC fan
I have a MinnKota Terrova with the same release set-up. If I read your question correctly: in order to deploy the motor, push the release handle in and then down. Hold onto the head of the motor so it doesn't slam down.
Let me know if that answers your question.
F225 Yamaha
F225 Yamaha
blacklabjeff
If the shaft appears to be stuck, you can use something like Armor All, or another cleaner/protectant to slick up the shaft. Be careful though, as once you clean and put the stuff on, the shaft will be pretty slick. It should deploy easily. I have a PD-2 and had the problem on my fish/ski boat and this did the trick. (You could probably use WD-40 also).
