Extending my Attwood Swivl-eze Seat?
Mosnowman
#1 Post by Mosnowman » Thu Jul 03, 2014 5:11 pm
Has anyone had success with installing a longer post on their Attwood Seat? It is factory installed and as you can see in the picture the length is short! After visiting the Attwood site I am now more confused as to whether their is an easy mod? I simply would like a longer post and the ones at Bass Pro have a black plastic wedge on the bottom which I think are not thick enough? Anyway....thoughts?
http://i1118.photobucket.com/albums/k60 ... 2d4b80.jpg
http://i1118.photobucket.com/albums/k60 ... c3787c.jpg
BUSY LIVING...
Columbia Mo BZLIVN
rancherlee
Re: Extending my Attwood Swivl-eze Seat?
#2 Post by rancherlee » Fri Jul 04, 2014 5:33 am
usually the post is welded to the base underneath. How much more height do you need? if its just an inch or two you could make some spacers/rings out of 3/4" marine ply to place between the base and the floor or make a spacer for the 6" square between the seat and the top of the mount and use longer bolts.
sunedog
#3 Post by sunedog » Mon Jul 07, 2014 5:30 am
I don't know about extending your existing pedestal, but for $79 you can make the problem go away. I bought this and it was the best $79 I ever spent on the boat.
http://www.amazon.com/gp/product/B00160 ... 00_s00_i00
rockymax
#4 Post by rockymax » Mon Jul 07, 2014 6:25 am
I replaced my original seat along with a longer post and new base. Remove the seat from the post The post should twist out but, if you cannot get it out, simply unscrew the base and install a new base with a new post. It is an easy task.
23' Hurricane
250hp Yamaha
Madison, AL
Wheeler Lake (TN River)
Mosnowman
#5 Post by Mosnowman » Mon Jul 07, 2014 6:43 am
Thanks for the replies!
So my next concern is that if I have underskinning I am worried when I unscrew the base the nut will drop? Or are those screws screwed into a permanent fixture or simply the plywood underneath?
Also the amazon suggestion...how is that any different than what I already have? The pictures may be deceiving but is it a lot longer base?
I'm not a skilled do it your selfer so I am very cautious before I possibly mess something up. :hammer
BUSY LIVING...
Columbia Mo BZLIVN
Waterlogged
#6 Post by Waterlogged » Mon Jul 07, 2014 9:04 am
I put a 1in. wood spacer between the square pad on top of post and the seat. Quick easy and cheap, and should last the life of the boat.
Glenn
2008 Mercury 115 4 stroke
#7 Post by RcgTexas » Mon Jul 07, 2014 9:05 am
Here are the pedestals I bought from pontoon stuff.com ( a sponsor here).
With the tape it might show that you adjust them just like you want them.
