New Tire Question
New Tire Question
Ok, so I finally got two new tires under warranty installed last week (because of a rotten new tire) on the trailer (single axle). The tire specs are the same by weight and psi, so I know they will carry this load. They are at max psi of 50 right now. They are a different brand from before as well which is a good thing I guess? Anyway, I'm particular with tires, and these look under-inflated. What gives? Should I worry about this? Taking an early morning fishing trip tomorrow, and any response would be appreciated. Thanks
- NewTire2.jpg (72.26 KiB) Viewed 1210 times
- NewTire1.jpg (98.92 KiB) Viewed 1212 times
2014 Sweetwater 2086SW
90 Hp Yamaha 4-stroke
Re: New Tire Question
That's a radial tire and is supposed to have some squat to it...
PHEW!!! Did I mention I'm really new at all of this and rely on all of you for expert advice. Thanks again!
Your welcome...Trust in common sence and don't sweat the small stuff...C_M_25 wrote:PHEW!!! Did I mention I'm really new at all of this and rely on all of you for expert advice. Thanks again!
Looks right to me
Once it has ran a bit it will puff up.
