New Tire Question
C_M_25
New Tire Question
#1 Post by C_M_25 » Fri Aug 15, 2014 4:58 pm
Ok, so I finally got two new tires under warranty installed last week (because of a rotten new tire) on the trailer (single axle). The tire specs are the same by weight and psi, so I know they will carry this load. They are at max psi of 50 right now. They are a different brand from before as well which is a good thing I guess? Anyway, I'm particular with tires, and these look under-inflated. What gives? Should I worry about this? Taking an early morning fishing trip tomorrow, and any response would be appreciated. Thanks
2014 Sweetwater 2086SW
90 Hp Yamaha 4-stroke
teecro
Re: New Tire Question
#2 Post by teecro » Fri Aug 15, 2014 5:14 pm
That's a radial tire and is supposed to have some squat to it...
C_M_25
#3 Post by C_M_25 » Fri Aug 15, 2014 5:26 pm
PHEW!!! Did I mention I'm really new at all of this and rely on all of you for expert advice. Thanks again!
teecro
#4 Post by teecro » Fri Aug 15, 2014 5:29 pm
C_M_25 wrote:PHEW!!! Did I mention I'm really new at all of this and rely on all of you for expert advice. Thanks again!
Your welcome...Trust in common sence and don't sweat the small stuff...
#5 Post by lakerunner » Fri Aug 15, 2014 5:37 pm
Looks right to me
MH Hawker
#6 Post by MH Hawker » Fri Aug 15, 2014 8:59 pm
Once it has ran a bit it will puff up.
