sorry if my "Best propane heater" thread is a repeat,,,,
But the search function sorta failed me. I'm looking for a propane space heater for the Party Hut. Got plenty of ventilation and use the boat year-around so I need big heat and economical to boot. Probably a pipe dream right?? LOL Looking for first hand knowledge cuz reviews are all over the place and I want to hear from fellow boaters on what works and what doesn't,,,, thanks !!
Re: sorry if my "Best propane heater" thread is a repeat,,,,
Check with Rv parts dealers, in my old RV I had a 12 volt forced air furnace and a space heater mounted in the cabinet by the door so you can run extra heat up front, after a quick look at Campers World I found a few,
http://www.campingworld.com/shopping/it ... ater/48574
This is like the one I have up front of my camper, if it looked newer I'll just sell you that one
http://www.campingworld.com/shopping/it ... ater/19333
- rancherlee
the Big Buddy is a nice unit with a bit in Fan that runs forever off 4D batteries. Plenty of heat also, use mine icefishing all winter and even heats up my 20x24 garage nicely when I need to wrench on something in the winter.
- killerkernrich
Olympian Wave 6 Catalytic Safety Heater, is a nice unit I don't have one in my Camper but a buddy does and he likes it, his is piped into his propane.
PLP Member
NRA member
UFC fan
PLP Member
NRA member
UFC fan
That wave heater is really thin !!! Thanks for the link,,, a bit pricey compared to the others,,, not sure why?HandymanHerb wrote:Check with Rv parts dealers, in my old RV I had a 12 volt forced air furnace and a space heater mounted in the cabinet by the door so you can run extra heat up front, after a quick look at Campers World I found a few,
this is the one I'm leaning towards at the moment. Can it be run WITHOUT the fan running? (in case we run out of batteries)?rancherlee wrote:the Big Buddy is a nice unit with a bit in Fan that runs forever off 4D batteries. Plenty of heat also, use mine icefishing all winter and even heats up my 20x24 garage nicely when I need to wrench on something in the winter.
Here's a couple of heaters I picked up at flea markets . The one on the left "Mr Heater" is for inside the 8x12 cabin and the other is for outside on deck. Both are propane and work very well but I live in central fla. and we don't see winters colder than the 30's.
- 20150216_134306.jpg (209.83 KiB) Viewed 2852 times
Never gave a thought about the front of the boat. Not sure I have room for the heater like you have there,,,, how far away does the heater need to be from combustibles???
- killerkernrich
here is a small little buddy good price an free s&h
http://www.amazon.com/dp/B001CFRF7I/ref ... 0e744643_S
PLP Member
NRA member
UFC fan
PLP Member
NRA member
UFC fan
,,,, thanks for the link,,,, but I need the BIG ONE
grunt grunt grunt (My best Tim-the-tool-man grunt!!!)
I just climbed off my boat after taking a couple of measurements. Even at 20 below (and dropping), my Little Buddy was enough to keep my 8x8 shack tolerable. A word of caution tho, I killed one several years ago by not using a filter in line between the 20# tank and the Buddy. The Mr. Heater guys said the orifices are very small and hard to clean. Since I got my new one and change filters once a year, not a single problem.
that's the first time I've heard of an in-line filter for LPG,,,, gonna do a search on that to get edumacated
- Mosnowman
I don't think anyone answered your question about the fan running. You can definitely turn the fan off and still not lose efficiency. I generally leave it running to disperse the heat a little better.
BUSY LIVING...
Columbia Mo BZLIVN
Columbia Mo BZLIVN
Thanks for noticing that !!! I was trying to be very patient and not nagg about it ,,,hehehehehMosnowman wrote:I don't think anyone answered your question about the fan running. You can definitely turn the fan off and still not lose efficiency. I generally leave it running to disperse the heat a little better.
