New battery charging problem for yews smart guys,,,,
grouser
Re: New battery charging problem for yews smart guys,,,,
#16 Post by grouser » Sat Mar 21, 2015 8:58 am
mgarvie wrote:Could try an inverter/generator. I have a Champion 3100 watt that runs my led tvs and computer just fine. Affordable and pretty quiet. Got one for emergencies at home and to take camping on the boat to run an ac for my tent.
I thinks this is what Honda has done for such clean power. And if I bought a new gen-set that would fix the problem,,,, if I want to listen to the thing run for X number of hours,,, I think the inverter is what I'm looking at to throw in between the generator and the battery charger to keep it clean,,,
will search for it on the net,,, thanks
grouser
#17 Post by grouser » Sat Mar 21, 2015 9:02 am
Bryden24shp wrote:#2 on the second alternator. Can you run a 12 volt and battery selector switch instead of going 36 volt?
not sure I'm following you here...
my trolling motor is 36 volt,,,, can't change that,,, or don't want to, me likes the 36 volts for that set-up
are you saying use a battery switch to isolate the three batteries to make them 3 12 volt batteries again and use a second 12v alternator to charge them? I dunno if that can be done,,,,l'm not smart enough to know that !!! :donno but it sounds interesting?
#18 Post by Bryden24shp » Sat Mar 21, 2015 1:46 pm
grouser wrote:are you saying use a battery switch to isolate the three batteries to make them 3 12 volt batteries again and use a second 12v alternator to charge them? I dunno if that can be done,,,,l'm not smart enough to know that !!! :donno but it sounds interesting?
Yep!
grouser
#19 Post by grouser » Sun Mar 22, 2015 5:19 pm
hummmm now I got another way to fix this problem,,, thanks !!!!!!
I will look into it
babock
#20 Post by babock » Sun Mar 22, 2015 10:19 pm
rancherlee wrote:You can also charge a 36v bank off a 12v source using a lot of heavy duty diodes but I really don't like that method.
That is impossible.
Mercury 90 4 stroke
#21 Post by HandymanHerb » Mon Mar 23, 2015 1:06 am
You can wire three batteries in parallel to charge all with 12 volt, while still hooked up in series for 36 volt at the same time,only, so you can use 12 volt off one or all of the batteries at the same time you are wired for 36, DC can be run in series and parallel at the same time, so you can build up voltage or build up amps in storage for use
Dam you made me think back 37 years to DC class at Beep school
babock
#22 Post by babock » Mon Mar 23, 2015 12:34 pm
You can not have 3 batteries wired up in parallel and in series at the same time.
Easy to draw up a diagram and you will see why it can't be done.
Mercury 90 4 stroke
#23 Post by HandymanHerb » Mon Mar 23, 2015 12:48 pm
Yes it can, it is done all the time, try it and see, your only getting the voltage to that the load is tapped too, so you can get 12,24 or 36 all out of three batteries at the same time.
My TM is 36 volt, so I'm in series on three batteries for 36 , the same batteries at the same time I ran the radio and all the toys off the TM batteries at 12, I hooked the 12 volt in parallel so not to just drain one battery and ran like that for five years
All MCI buses uses 24 volts to start in series but everything on the bus is 12 volt, wired parallel from the same two batteries
babock
#24 Post by babock » Mon Mar 23, 2015 1:59 pm
Take 3 D batteries and wire them in series. Then take some wires and add parallel connections so that all 3 batteries are in parallel as well. Be careful, your hand will get burnt. :lol3
If you are just talking about putting a load on one of the 12V batteries, that is something completely different and that is not putting the batteries in parallel.
This is 3 batteries in parallel
This is 3 batteries in series
Take that series connection and add connections between all positives of the batteries and then connect all the negatives and you have a massive short.
Mercury 90 4 stroke
#25 Post by HandymanHerb » Mon Mar 23, 2015 2:56 pm
The batteries can be in different counties for all I care, it's the circuits (the way the wire runs) that are series or parallel or both as needed, prove it to your self wire batteries in series and then use a volt meter on each battery and tell me the voltage isn't still 12 volt on each battery using the + - on each battery.
So like has been done, going from neg on first battery and pos on 3rd battery will give you 36 for your TM, at the same time you can run wires to each + - of each battery put all the +'s and -'s together , you now have 12 volts and 36 at the same time,off the same batteries or a series, parallel circuit that will stay balanced
grouser
#26 Post by grouser » Mon Mar 23, 2015 3:11 pm
Fuk you guys make my head hurt :scared
Bamby
#27 Post by Bamby » Mon Mar 23, 2015 3:21 pm
OK You Two What do you think about this layout...
Batteries in Series 36 v 12 v.png (19.74 KiB) Viewed 2161 times
Since marine batteries come with duplicate posts on each connection why not utilize them in making this work for the man?
Note on second thought I need to look deeper into this... My batteries have two distinctive attachment points separated in non conductive plastic. I realized after posting many batteries are conductivity connected so this wouldn't work for them... Will haft to look deeper into subject.. :coffee
babock
#28 Post by babock » Mon Mar 23, 2015 3:28 pm
The 2 batteries on the left have dead shorts!
EDIT: All the batteries have dead shorts.
Uhghh! Where's the "bang my head against the wall" icon!
Bamby wrote: Note on second thought I need to look deeper into this... My batteries have two distinctive attachment points separated in non conductive plastic.
Yes, and they are electrically connected! All marine batteries that have the extra post are still electrically connected!
Mercury 90 4 stroke
babock
#29 Post by babock » Mon Mar 23, 2015 3:32 pm
grouser wrote:Fuk you guys make my head hurt :scared
Better than blowing up your batteries when you try this scheme!
Mercury 90 4 stroke
cleatus
#30 Post by cleatus » Tue Mar 24, 2015 7:06 am
one word - HYDRO-GENERATOR!
/not smart guy
//just stirring it up :lol3
here, pull my finger
2011 Godfrey Sweetwater
Yamaha F70
