Ski/Tow Bar Installed
bivey79
#1 Post by bivey79 » Thu Jul 16, 2015 5:54 am
My Ski/tow bar finally came in and had it installed yesterday. Really looking forward to trying it out this weekend.. :alright
[color=#800000]2015 Sun Tracker Fishin Barge 20 DLX with Merc 90HP Command Thrust[/color]
[color=#FF0000]Keep calm and Toon on![/color]
trucky
Re: Ski/Tow Bar Installed
#2 Post by trucky » Thu Jul 16, 2015 6:40 am
Pics...
Or it never happened (or so I've been told)
#3 Post by RcgTexas » Thu Jul 16, 2015 6:42 am
We have to have ---------- :pics
PartyToon75
#4 Post by PartyToon75 » Fri Jul 17, 2015 3:23 am
Looks good, I had mine installed earlier this week too. :nana
-Lawrence-
2015 Sun Tracker PB22 DLX
teecro
#5 Post by teecro » Fri Jul 17, 2015 6:05 am
This is mine built in the driveway in a couple of hours with nothing but hand tools from 1.5" (1.9" OD) Alum Pipe and Cast Alum Construction Fittings as sold at many Industrial Suppliers to which I used http://www.mcmaster.com (http://www.mcmaster.com/#4698t81/=y3apk1) I upped the strength by removing the 1/4" pin used to join the swivels and replaced with 5/16" cap screws and pinned the pipe in the fittings with 3/8" cap screws, also used 1/4" thick plate under the decking to sandwich the flange fittings to the deck. It now has a plastic swivel bushing at the rope attachment point to allow the rope to swing side to side and cause no chafe. Used the stink out of it with up to 3 people on the tube and it works great.....
tow bar.jpg (126.88 KiB) Viewed 7749 times
bivey79
#6 Post by bivey79 » Fri Jul 17, 2015 6:27 am
Nicely done teecro!
teecro
#7 Post by teecro » Fri Jul 17, 2015 6:32 am
bivey79 wrote:Nicely done teecro!
Thank you Sir!
I live very much off the beaten path and there is nothing I dislike more than having to go into town as just the drive takes least 3 hours out of my day... The UPS man dropped it all off at the house for about 200 dollars...
#8 Post by RcgTexas » Fri Jul 17, 2015 7:18 am
Both of them look very good! I wish my boat was two feet longer and I had that two feet on the stern to put one on.
teecro
#9 Post by teecro » Fri Jul 17, 2015 8:01 am
RcgTexas wrote:Both of them look very good! I wish my boat was two feet longer and I had that two feet on the stern to put one on.
That's one of the reasons I rolled my own was that many of the topside mounted 4 point bars used up more real estate than I had to spare. I don't recall the width if my overall footprint was even 18 inches... But I understand some boats don't have an open stern at all.
Littlehoe
#10 Post by Littlehoe » Fri Jul 17, 2015 8:40 am
We opted for the Turboswing because I didn't want to lose any of that swim platform area. This boat has about a 2 foot platform that wraps around the engine/transom and the kids are always playing on it or jumping off it.
wvbassmistress
#11 Post by wvbassmistress » Fri Jul 17, 2015 12:00 pm
bivey79,
Looks like you have the same boat we do with the same problem of where to put a tow bar.
Where did you get this! It is perfect. How does it attach?
Thanks in advance.
BTW, we spend some time fishing Lake Guntersville. Do you make it there often?
bivey79
#12 Post by bivey79 » Fri Jul 17, 2015 12:07 pm
I had Tracker in Florence, AL install it, but from what I can tell, they mounted extra bracing to the floor bracing and bolted it down. I will snap a few extra pics when I get home if you want?
We were in Guntersville at the bat cave this past weekend. We spend most of our time at Tim's Ford in TN when just going to relax. For fishing, we will be in Guntersville.
#13 Post by RcgTexas » Fri Jul 17, 2015 8:13 pm
First time I have seen one like that on a toon! Seen em on fishing boats but I like it! :idea:
