Speakers mounted on Ski tow
- rsscoggins
All
We just put a deposit down on a Sylvan 8522 Mirage Cruise LS. Full tube tritoon with a 150 Yamaha. For us the Sylvan seemed to be the biggest bang for the buck.
I will be adding an amp and a few more speakers myself but want some speakers that we can hear while floating in the water. I know the "roll bar" boats (ski boats) mount them on the towers, but has anyone mounted a pair of speakers on the ski tow - the one we ordered sits in front of the engine and is not a single pylon/bar. Perfect place for some speakers.
Thoughts? I tried searching but depending on the search terms, I either come up empty handed or 30 pages of stuff and still haven't found what I was looking for.
Re: Speakers mounted on Ski tow
I've seen them on ski tow bars and also on the back rail of the pontoon depending on what you have and if you can clip them to the back rails. The hardest part would be getting a clean install with the wires. I suppose you could drill and fish the wire out the bottom. If you fish the wire through the bar I would use rubber grommets to seal the tow bar as well as protect the wire. An alternative would be mounting the speakers close to floor level so you don't have to go as far with the wire and just bring the wires out the transom.rsscoggins wrote:All
For $200.00 I'll sell you the ones I just took off of my boat. I replaced everything with Rockford Fosgate.
IMG_2747 by my99svt, on Flickr
IMG_2749 by my99svt, on Flickr
IMG_2751 by my99svt, on Flickr
IMG_2753 by my99svt, on Flickr
They are the 6.5 Polk DB series.
IMG_2753 by my99svt, on FlickrThey are the 6.5 Polk DB series.
Tim
Broken Arrow, OK
Lake Tenkiller
2012 JC Sunlounger Sport 25'
Honda 250 powered
2015 Chevrolet 2500HD High Country Duramax powered
Broken Arrow, OK
Lake Tenkiller
Honda 250 powered
that would be pretty cool. fishing the ski tow bar wouldn't be too bad. one hole at the base with a grommet and one at the speaker mount. you might be able to unbolt the base of the tow bar and feed the wire up the hollow bottom. they are pricey, but wet sounds makes a nice swivel mount so you could change the orientation depending on whether you were in the boat or the water.
2002 MasterCraft X30
2007 Yamaha FX HO Cruiser
2005 Kawasaki SXR800
2004 Yamaha SuperJet
1989 Kawasaki 650sx
Lewis Smith Lake, Alabama
1989 Kawasaki 650sx
or you could get an Engel cooler stereo http://www.carid.com/engel-usa/cooler-d ... gQodG3sABg and float it in one of these http://www.amazon.com/Connectable-Coole ... rce+cooler
I have a new Avalon coming and I have thought about doing the same. There is a an audio shop right across from the boat dealer, so I plan on going over there and asking what they think the best approach is. If I get any good info I will pass it along.
2016 Avalon 2785QL Windjammer
2016 GMC Denali 1500
- rsscoggins
Where did you have these mounted? What is the inside diameter (ID) of the clamps? Can the clamps be rotated?my99svt wrote:For $200.00 I'll sell you the ones I just took off of my boat. I replaced everything with Rockford Fosgate.
I had them mounted on my wakeboard tower. The inside diameter is 2.25"
The clamps cannot be rotated but, they can be removed.
P1000933 by my99svt, on Flickr
P1000933 by my99svt, on FlickrTim
Broken Arrow, OK
Lake Tenkiller
Honda 250 powered
Broken Arrow, OK
Lake Tenkiller
Honda 250 powered
- rsscoggins
Definitely interested. We are test driving a similar boat tomorrow before we finalize the details on the one we are ordering. I will measure the ski tow diameter (got to remember to bring my calipers) to see what size it is.my99svt wrote:I had them mounted on my wakeboard tower. The inside diameter is 2.25"
It looks pretty beefy (picture below) but not sure it is 2.25" like the wakeboard tower. Do you know if they make different size clamps? Who makes the cans and I can research it?
Wow, I forgot how much I paid for these! I'm sure you could put more rubber inside them to clamp on a smaller tube.
http://www.h2osportswarehouse.com/produ ... 225-pa.htm
Tim
Broken Arrow, OK
Lake Tenkiller
Honda 250 powered
Broken Arrow, OK
Lake Tenkiller
Honda 250 powered
- rsscoggins
Cool - let me measure tomorrow and I will let you know. Definitely interested just need to make sure that the ski tow is between the 1.5 to 2.5" the link specifies.
that screw crossing the upright bar just above the weld may cause some issues. hopefully you'll be able to access the nuts underneath the deck and work from the underside. as far as the diameter of the bar. i've put several extra racks on my tower on my mastercraft, and they all pretty much just use rubber strips to compensate for differences in diameter of various towers. also forgot to mention, $200 is a good deal on a set of tower speakers. if you don't want them, please let me know. i have a roll cage on a bronco that could use those speakers.
1989 Kawasaki 650sx
1989 Kawasaki 650sx
- rsscoggins
I measured the ski tow and I think we are good.
I will take them for $200. Contact me via PM and we can arrange shipping and payment.
We are in the DFW area. Where are you?
Broken Arrow, ok. Tulsa area.
Tim
Broken Arrow, OK
Lake Tenkiller
Honda 250 powered
Broken Arrow, OK
Lake Tenkiller
Honda 250 powered
